having trouble with dash turns on and off when going down the road
BossMan74
ok this is what going on ! im going 60 then the hole dash gos down to 0 like if it off ?? help plz
theautoman21
not sure what type vehicle you have but you might check your connections at your instrument cluster if it has a connector that plugs into it or where the cluster plugs into a plug when inserted to where it goes and also your stereo not sure on that iether but those are good starting points hope it helps if need more help let me know !!
SabrToothSqrl
wow
"Here is what is happening, while driving sixty miles per hour, the entire dash stops functioning. It is similar to when the vehicle is shut off. Can you please help me? Thank you. "
Now, what kind of vehicle is this? Year, make and model please.
JohanZ
