Hard shift into top gear
Jdsfx1
I’ve tried searching for a similar symptom here, but didn’t see my exact problem. When accelerating it shifts smoothly through the gears until the final gear (6th?) and then it shifts hard into final gear. I’m not accelerating hard, just taking it easy. It also does it if I let cruise control take me back to speed. I have found I can feather the pedal sometimes and make it shift smoother but I know I’m just masking a problem.
I do plan on a filter and fluid change in the coming days.
Any thoughts on cause? It’s a 2008 Yukon Denali 6.2
NickTransmissions
Sin City
The transmission bench
What have you done thus far, if anything, to diagnose the problem?
Do you have a bidirectional scan tool that can display live engine and transmission data?
Marky Dissod
I’ve tried searching for a similar symptom here, but didn’t see my exact problem. When accelerating it shifts smoothly through the gears until the final gear (6th?),
and then it shifts hard into 6th. I’m not accelerating hard, just taking it easy. It also does it if I let cruise control take me back to speed.
Any thoughts on cause? It’s a 2008 Yukon Denali 6.2L
See if cleaning the MAF with MAF cleaner helps. (Anyone else know what else is safe for cleaning MAFs?) Also, something about the throttle modules ...
J
Jdsfx1
I don’t have a bidirectional scan tool and haven’t done anything yet to troubleshoot, I figured I’d start here since every problem known to man seems to have discussed/diagnosed by our forum members. I guess I need to break down and buy a good scanner sometime soon.
Marky Dissod
Fixed.
Mechanic-grade tools are available now at prices that'll make it plainly obvious that dealerships won't stop overcharging you til you stop going to them.
I recommend that you get yourself a quality bi-directional scanner to add to your tool box. Then, you will be able to read ALL trouble codes, along with a brief explanation/pointer to the source of your issue. You can test many of the truck's electronic functions with the scanner, in order to determine the source of an issue. You can log data to observe realtime functioning of various modules and systems in your truck to identify abnormalities in their operation. You will also be able to reset/delete trouble codes, after taking corrective action. You will literally save thousands of dollars in diagnostic and repair costs over the life of your truck, and you will most likely recoup the cost of the scanner within 1 year.
Perfect example here...... If you had a bi-directional scanner, @NickTransmissions may have been able to guide you in some preliminary data collection activity that would help identify the source of your issue.
J
Jdsfx1
Ok, I bought a bi-di scan tool, but don’t see any codes related to trans. Any advice on what I should look for with the scanner?
NickTransmissions
Sin City
These situations are often TEHCM-related and would usually throw a clutch pressure control solenoid or pressure switch related code. If you're not seeing anything then it's possible that the symptom is an indicator of either TC pending failure and/or worn pressure regulator valve. Another possibility is the valve body, specifically the 2-6 and 456 clutch boost and clutch regulator valves. Though hard downshift would be present when transitioning from 3rd to 2nd gear if the 2-6 valve train was sticking and a solenoid performance code would likely set and store; likewise from 4th to 3rd if the 456 valve train was sticking.
Scanner: Monitor the shift speeds from 5-6 and compare them to all other gear transitions - accelerate uniformity as possible when doing this so that you don't introduce any variables into the readings. If shift speeds from 5th to 6th gear are markedly faster than all others, assuming equal acceleration rates, that would indicate higher line pressure than normal when shifting into sixth gear. Higher line pressure would have to then be confirmed with a mechanical pressure gauge (or the scanner if yours can output LP data). Once confirmed, diagnosing the high/excessive line pressure condition would then begin.
Let us know what you find when you drop the pan; cut the filter open to see what is being collected inside of it - report any excessive clutch matter, metal, etc.
Mariam26A
