Got new LEDs for the grille guard and fogs-
thegeneral
ImageUploadedByTapatalk1371950647.535968.jpgImageUploadedByTapatalk1371950675.116025.jpgImageUploadedByTapatalk1371950695.045370.jpg
thegeneral
thegeneral
Thanks! Yea it's like daylight with them on...
thegeneral
thegeneral
The fogs are great! Got them from ledwarehouse.com i did order the 90* flood as opposed to the spot beam. they were a simple install. I removed the old fog lights, and right above the existing fog light opening is a factory drilled hole for the front lower valance. I took the plastic peg out, took out the existing nut that held the peg and used a couple 3/8x2" grade 8 bolts and nuts I had laying around to secure the led bracket.
I then spliced into the existing fog light wire. If you're doing this, remember LEDs are polar, meaning the neg has to hook to the factory neg, and the positive to the factory positive for them to work. I believe the factory positive was purple, but I could be wrong.
Very effective lights, and the install was a piece of cake. ~2 beers. Maybe 3 if its hot out.
millertime8874
