GM What's the deal with your engines?
llllljrlllll
los angeles
I bought my truck brand new in 2007, and I've never had such a bad experience with buying a new vehicle. I thought that GM Trucks were reliable and strong vehicles. That as long as I maintained it, oil change, good gas, tune up, that this engine would last me past the 200k mark...I would never had thought that at 138k the engine would throw me a curve. I've had the same problem as everybody else, with oil consumption on this engine and GM saying that it is normal for oil to burn on this engines, Specially since I've just found out that my LS has a 5.3 engine so I figured it's normal. I've also read somewhere online that GM while building this engines they didn't align the rings how they needed to be on the piston causing that famous burning oil. Which would make sense, oil slipping through rings= burning oil. But can anybody explain to me why at 138k I need to have my Tahoes engine rebuilt. I was driving to work, when my engine started sputtering and knocking, stabilitrak off, CEL ON, hooked up my machine to it and it gave me P0301, I took it to the mechanic, misfire on cylinder 1. Mechanic checked my spark plugs, wires, coils, everything OK, still the knock, then he hooked up the compression machine to check compression on the engine, and guess what!!!! NO COMPRESSION, he explained to me that is very common for GM engines to have this problem, and unfortunately his diagnose for my Tahoe was to have the engine rebuilt. WHAT!!!!! $3k to have it done, GM can you explain to me why I have to rebuild and engine at 138k, I knew that at some point I would have to do that, but at 138k come on, your consumers buy your product thinking that they have a quality USA product, I've had quite a few problems with my trucks as some as you guys know, in case you didn't here are a couple of threads I've started. http://www.tahoeyukonforum.com/forum/showthread.php?t=21252 , http://www.tahoeyukonforum.com/forum/showthread.php?t=21570 but this is just BS, yes, I know in this case I turn to our GM people and asked them what can you guys do for me in this case. Should an engine need a rebuild after it has been taken care of. And at 138k, any help would appreciated it.
imi4tth3w
Texas
does your motor have the 4/8 cylinder mode? heard going into the 4 cylinder mode really hurts these motors. can be disabled via a custom tune. but i guess thats a little late. sorry about your motor man but there's not a lot you can do now except fix it or not.
L
llllljrlllll
los angeles
I didn't know that the change from 8 to 4 on highway would hurt this engines, something new to know. As far as the engine is concern, I have a 2007 LS with a 5.3 engine, there is really not much I can do at this time, can't trade it in like this, otherwise the dealer would murder me in what they want to give me. The situation on this truck sucks. 138k on an engine, come on, my 97 civic, has 185k and she's running fine. If you guys thinks it's fair for this to happen, then by all means let this happen to you, and lets see how the table turns. The most I haul in this vehicle is 3 little boys under the age of 10, I would understand towing a boat or using this on a construction site hauling concrete, but this is your everyday Tahoe, family truck. Keep hoeing
08grey
Unless you did their oil consumption survey thing where they make you bring it in to refill each time they won't help you.
That motor would get allot of build up on top of the four cylinders that won't detonate when in 4 mode. Not to mention the lifters gunk up. This is a recipe for disaster once those four kick back in.
I suggest you rebuild the motor to your liking with a cam n such. 3k should be more than enough to get some nice custom additions and get a blackbear tune to know out the 4 cyl mode. Your not alone I have read many a thread of people in your same situation, I don't want to sound inconsiderate but there are many in the 60- 80k range with the same issue. It just sucks.
livingez_123
Sandy, OR
As long as the engine made it past the warranty period GM is ok with it. I remember when going 100k on a stock engine was a huge milestone. I put 600k on my diesel in my Dodge before I sold it. the new owner put another 250k on it. I still think anything over 100k on a V-8 and your doing good. Now these little inline 4 cyl engines seem to run forever but that is in it's design. A inline will last much longer. So sure it sucks to need a rebuild at 138k. Get a reman short block freshen your heads and you will have way less than 3k into it.
L
llllljrlllll
los angeles
Well that is what I got quoted, 3k to get it rebuilt, I just think that it sucks that I would have to fork this money, I waited for this new body style to come out, it was the 2nd Tahoe sold of the lot, I picked it out of the truck as it came into the dealer. But then again GM knows of the problem and they don't do nothing to remedy this problem. How can you have recurring business if you don't take care of the issues that you have now. The answer per GM is that it is normal for engine to burn oil. Maybe it is, maybe it's not. I just think it sucks.
TheFuzz
Idiot Police
Spurbury, VT
Couple of things -
1. That sucks. 138k on these motors shouldn't even phase them. Needing one rebuilt at such low mileage is really unfortunate. Maybe I'm spoiled as a former Toyota owner...the ***-built 4.7 in my landcruiser had 150k on it when I traded it on my Tahoe and it ran like a top. Several others I've seen had 500K on the original motor/tranny. Gutless though, hence the trade.
2. Take this and use it as an opportunity to have some fun. Add a cam, new lifters, valves, valve springs and disable AFM, and build a motor that makes some nice power with close to stock reliability (I say stock reliability based on how the motor SHOULD be, not how yours is). $3k is steep for a basic rebuild though, I'd check out another shop unless you have a solid relationship with that one.
L
llllljrlllll
los angeles
Well see, that's the thing, other car companies are running longer on their engines, just like your example. Why shouldn't a car like mine not make it past 138k. I'm a family guy, just like most of you, with 3 kids, I just can't fork out 3 grand, and not be upset at the fact that my Tahoe just took a dump. Because of a flaw that GM knew about. Misfire on piston 1 come on, P0301, no compression. It pisses me off man. Thank the lord that I have another car, otherwise I would of been f%*&ed. I work and hr and half away from home. No car, means hrs on the bus. Specially for a car that I paid 40 grand for.
---------- Post added at 09:13 PM ---------- Previous post was at 09:08 PM ----------
Couple of things -
Well, thats the thing, I don't even know if 3k is the norm. I think mechanics just here 2007, and they think this guy needs this car let's charge him 3g's. As far as a shop, I don't even know where to begin, this is the first time ever that I would have to rebuild an engine. I don't even know what to add to make it better. I live in cali, in Monterey Park, any suggestions would be appreciated. But if GM is willing to help out, I don't mind taking it to the dealer and paying them.
TheFuzz
Idiot Police
Spurbury, VT
No denying that it sucks. It truly does. The problem is that you are in a serious minority compared to the hundreds of thousands of these trucks running around today that are running fine. GM isn't going to fork over anything to fix it even if it is their fault simply due to the cost of the repair, and the fact that they can't prove (without tearing into the motor) what caused the damage.
It's all a bunch of blame-game BS. Rather than spending money to re-grease a few squeaky wheels, they are betting that the noise from a few pissed off owners will get drowned out by the majority. Most car companies are that way once a vehicle goes out of warranty.
---------- Post added at 10:22 PM ---------- Previous post was at 10:14 PM ----------
Monterey Park is an LA suburb, right? If so you're in luck, Black Bear Performance is based out of San Diego, they are the ones that do 99% of the engine tuning on this forum. Justin and Jenna are fantastic. They aren't a full blown shop (mostly just engine tuning and performance parts), but if you send a PM to Jenna (username JennaBear) I'm sure she could point you in the right direction.
L
llllljrlllll
los angeles
I know and I hear you. But I'm making some noise, because I am part of that minority. I paid good money for vehicle that I thought would last me past the 200k. I had few run up with GM and their dealers, check the thread I have posted before my 100k mark, and some would say my Tahoe is a lemon. But I've gone through incompetent mechanics at the dealers, and so forth. With this being the last straw, like I said I'm mad as hell that his happened. And I am venting. And just like anybody in my position I want a solution... Or options.
---------- Post added at 09:27 PM ---------- Previous post was at 09:24 PM ----------
Just saw the 2nd part you added, I will do that. Maybe they have a suggestion as to a shop, you never know, I might end up having a truck that will last me another 100k before the fenders and wheels fall off...lol
sumo
dn ʇǝƃ ʇuɐɔ & llǝɟ ı
rhode island
i complained about the oil consumption. It was a pain. In the end i was able to get the dealer to do a decarbon of the engine, Replace valve covers and install a shield in the lower part of the engine that surrounds the active fuel management solenoid.
L
llllljrlllll
los angeles
What does the shield do in this case? Decarbon the engine? What does this
for the active fuel management?
---------- Post added at 01:00 AM ---------- Previous post was Yesterday at 11:15 PM ----------
So I found this thread, this is the same exact thing that happened to me, with the cylinder 1 failure http://www.tahoeyukonforum.com/forum/showthread.php?t=50089. Read up on it, it will enlighten your mind....Keep Hoeing
---------- Post added at 01:35 AM ---------- Previous post was at 01:00 AM ----------
So I have found out upon reading all the threads that it's the active fuel management system that ruined my engine, if you read this, try to get bb to turn off the afm of your hoe, before the same thing happens to you. http://www.tahoeyukonforum.com/forum/showthread.php?t=43966
---------- Post added at 01:43 AM ---------- Previous post was at 01:35 AM ----------
And another on Sumos thread http://www.tahoeyukonforum.com/forum/showthread.php?t=44321&page=5
---------- Post added at 01:54 AM ---------- Previous post was at 01:43 AM ----------
And another, same issue, different description http://www.tahoeyukonforum.com/forum/showthread.php?t=44689
---------- Post added at 02:28 AM ---------- Previous post was at 01:54 AM ----------
another one http://www.tahoeyukonforum.com/forum/showthread.php?t=28322
L
llllljrlllll
los angeles
Interesting to know that just by switching over to engines and tranny and all traffic for this thread stops.
sumo
rhode island
Its like a chemical tune up. They let it a fluid sit in the engine for some time and what it supposed to do is breakup the carbon deposits that form on the valves, on the pistons and in the intake. they say if carbon forms around the valves, it can prevent the valves from fully closing causing oil to sneak by and get burned up. The shield in around the afm solenoid is to prevent oil spalshing past a certian point and getting burned up. Theres a bulletin that explains that but i have to hunt for it.
Here it is
If it doesn't correct oil consumption issue they must replace piston and rings! WOW
#10-06-01-008B: Engine Oil Consumption on Aluminum Block Engines with Active Fuel Man
xTooltipElement
Service Information
2009 Pontiac G8 | G8 Service Manual | Bulletins By Category | Technical | Document ID: 2596962
#10-06-01-008B: Engine Oil Consumption on Aluminum Block Engines with Active Fuel Management (AFM) (Install AFM Oil Deflector and Clean Carbon from Cylinder) - (Mar 7, 2011)
Subject: Engine Oil Consumption on Aluminum Block Engines with Active Fuel Management (AFM) (Install AFM Oil Deflector and Clean Carbon from Cylinder)
Models: 2007-2009 Cadillac Escalade, Escalade ESV, Escalade EXT
2007-2009 Chevrolet Avalanche, Silverado 1500, Suburban, Tahoe
2007-2009 GMC Sierra 1500, Sierra Denali, Yukon, Yukon XL, Yukon Denali, Yukon Denali XL
2008-2009 Pontiac G8 GT
Equipped with Aluminum Block V8 Engine with Active Fuel Management (AFM) (RPOs LC9, LH6, L76, LFA, L92)
with Greater than 45,000 km (28,000 mi)
This bulletin is being revised to add the 2009 model year and new Correction information for the 2009 model year - left rocker arm cover replacement. Information has also been added after step 9. Please discard Corporate Bulletin Number 10-06-01-008A (Section 06 - Engine/Propulsion System).
Condition
Some customers may comment about engine oil consumption of vehicles with higher mileage (approximately 48,000 to 64,000 km (30,000 to 40,000 mi). Verify that the induction system is assembled correctly and that there is no evidence that the engine has been ingesting dirty air due to a mis-assembled induction system. Also verify that the PCV system is functioning properly. If diagnostic procedures indicate that oil consumption is piston/piston ring related, verify that oil consumption is less than 3,000 km (2,000 mi) per liter/quart. If these conditions are met and oil consumption is less than 3,000 km (2,000 mi) per liter/quart, perform the service indicated in this bulletin.
Cause
This condition may be caused by oil spray that is discharged from the AFM pressure relief valve within the crankcase. Under most driving conditions and drive cycles, the discharged oil does not cause a problem. Under certain drive cycles (extended high engine speed operation), in combination with parts at the high end of their tolerance specification, the oil spray quantity may be more than usual, resulting in excessive deposit formation in the piston ring grooves, causing increased oil consumption.
Correction
2009 Vehicles Only
Important: This left rocker arm cover is NOT to be used on 2007-2008 vehicles because of the calibration of the PCV orifice being different in 2007-2008.
A new left rocker arm cover has been released for 2009 engines. Technicians should replace the left rocker arm cover with GM P/N 12642655. This rocker arm cover has relocated PCV drain holes that prevents PCV pullover into the intake manifold. Refer to SI for Valve Rocker Arm Cover Replacement - Left Side.
2008-2007 Vehicles Only
To correct this condition, perform the piston cleaning procedure as described in this document, and install a shield over the AFM pressure relief valve per the procedure outlined in this document. Monitor oil consumption after this repair to ensure oil consumption has improved to acceptable levels. If this repair does not correct the condition, it may be necessary to replace the piston assemblies (piston and rings) with new parts.
Important: It is critical in this cleaning process that the engine/fuel injector cleaner remain in the cylinders for a minimum of 2.5 hours to fully clean the components. The cleaner solution must be removed before a maximum of three hours.
Verify the oil consumption concern following Corporate Bulletin Number 01-06-01-011F. If oil consumption is found, continue on with this bulletin.
Remove the spark plugs and ensure that none of the pistons are at top dead center (TDC).
Clean the pistons by putting 118-147 ml (4-5 oz) of Upper Engine and Fuel Injector Cleaner, GM P/N 88861802 (in Canada, use 88861804), in each cylinder. Allow the material to soak for at least 2.5-3.0 hours, but no more than three hours and then remove the cleaner. A suggested method of removing the cleaner is cranking engine over. Make sure to unplug the ignition coils and fuel injector before cranking the engine over. Also make sure that the painted surfaces are covered so no damage is done.
Remove the oil pan. Refer to Oil Pan Replacement in SI.
Remove the AFM valve (1).
Install the new shield (1), GM P/N 12639759, and tighten the AFM valve to the oil pan to 28 N·m (20 lb ft).
Important: Ensure that the engine cleaner is thoroughly removed before reinstalling the spark plugs. Failure to do so may result in a hydro-lock condition.
Reinstall the spark plugs. Replace the spark plugs if necessary due to full of carbon. Refer to the parts catalog.
Reinstall the oil pan. Refer to the Oil Pan Installation procedure in SI. Replace the oil pan gasket if necessary. Refer to the parts catalog. Replace the engine oil if necessary.
Re-evaluate the oil consumption. Document on the repair order. If the oil consumption is still greater than 0.946 L (1 qt) in 3,200 km (2000 mi), replacement of the pistons and rings will be required.
Important: Some minor scratches may be noticed on the cylinder walls during piston and ring replacement. If the scratch cannot be felt when running your finger nail over it, the scratch is considered normal wear and the block or engine should not be replaced.
Parts Information
Part Number
Description
Qty
12639759
DEFLECTOR-OIL PRESS RLF VLV (quantity of 3 per order) (07-08 Models Only)
CLEANER, F/INJR 16 OZ LIQUID POUR (Upper Engine and Fuel Injector Cleaner) (07-08 Models Only)
COVER ASM-VLV RKR ARM (09 Models Only)
Warranty Information
For vehicles repaired under warranty, use:
Labor Operation
Description
Labor Time
J7555*
3.5 hrs
Install AFM Oil Deflector and Clean Carbon from Cylinder (4WD)
4.5 hrs
Install AFM Oil Deflector and Clean Carbon from Cylinder (G8 Only)
10.5 hrs
J7561
Rocker Arm Cover- Left Bank - Replace- (For 2009 Only)
0.6 hr
*This is a unique labor operation for bulletin use only. It will not be published in the Labor Time Guide.
GM bulletins are intended for use by professional technicians, NOT a "do-it-yourselfer". They are written to inform these technicians of conditions that may occur on some vehicles, or to provide information that could assist in the proper service of a vehicle. Properly trained technicians have the equipment, tools, safety instructions, and know-how to do a job properly and safely. If a condition is described, DO NOT assume that the bulletin applies to your vehicle, or that your vehicle will have that condition. See your GM dealer for information on whether your vehicle may benefit from the information.
WE SUPPORT VOLUNTARY TECHNICIAN CERTIFICATION
© 2011 General Motors. All rights reserved.
L
llllljrlllll
los angeles
Wow, I complained to my service tech about the oil consumption before my 100k mark, I had it in to replace a motor mount. And of course he said that it was normal for it to happen. In my case, I do a lot of driving in my truck, I work about 30 miles from home, and with LA traffic I'm siting in traffic from 1hr to 1 1/2. And I used to go to Vegas a lot. So my truck has a lot of highway miles which would explain the failure in my piston. This TB just pisses me off. This could of been prevented if he would of looked at his terminal for any TB.
GM Customer Service
Michigan
Hello,
I am sorry to hear that you are experiencing an issue with your vehicle's engine. I understand that you feel frustrated. I cannot guarantee anything but I would like to look into your concern. Please private message me.
Best regards,
Jennifer T.
GM Customer Care
cparedes
Bay Area
I had this oil consumption problem a year and half ago I only had 88k, problem turned out to be a bent lifter and a bunch of other major stuff, in short my whole engine was flooded with oil. Dealer quoted me $3k repairs, cuz I needed a engine & tranny rebuild. Tranny (stability track problem thing) But they talked to GM for me and GM reduce the quote which came out to $1800. The funny thing is, since I had all these problems with my Tahoe, I wouldnt trade it for anything else...
Fast55
Ventura County USA
Much of this became a problem when GM stopped sizing pistons to bores on an individual basis and started the "any piston fits in any bore" method of building engines. Within a specified range, any piston does in fact fit in any cylinder. Given that too tight of a final clearance is far worse than too loose, many engines will have one or more pistons that pretty much flop around in the bore. Worse still is that piston skirts have gotten shorter and ring tension lower in the name of fuel economy.
Do a search for "piston slap". No matter what they say, it is NOT a good thing to have a piston bang around in the bore, even if it you can only hear it when the motor is cold (typically goes away when warmed up). It's not just GM, and it's NOT just motors with AFM, not that it helps you fix your motor.
GM Customer Service
Michigan
Hello cparedes,
I apologize for any trouble you have had with your vehicle. That is great to hear GM was able to help out with your situation. I am glad to hear despite of all the issues with your Tahoe, that you still love the vehicle! We can be reached via private message if any other concerns or questions arise in the near future. Continue to enjoy driving your Tahoe!
Sincerely,
Laura M.
GM Customer Care
JR...I'm a little late to this but I had a VERY similar issue to yours just a few weeks back. My burb has 135k on it and I lost compression on cylinder #4. The issue was caused by a bad lifter and was a direct result of the crappy 4/8 cylinder mode crap. So I had them replace all the lifters on that side and now I've had that AFM tuned out so hopefully I'll be good going forward. If your shop is automatically jumping to needing the motor rebuilt I'd be questioning that!! It's most likely just a lifter that crapped out.
johnnycuatro
