Gieger counter noise
teddybear
Sounds like a gieger counter under drivers side dash. Tick click sound. Sometimes more clicks sometimes less. Does not do more or less no matter what you do. Steering, speed, bumpy road, nice road, moving steering column, turning. Turning off all electronics does nothing. Nothing changes the constant noise except stopping. Or going under 5 mph. Stops sometimes for no apparent reason. Sometimes for days. Sometimes for minutes. Making me crazy. Any ideas? Thanks 2015 Yukon Denali
wjburken
Eastern Iowa
Baseball cards in your spokes?
How loud is the noise?
have you pulled off the lower trim cover and tried to locate the source?, maybe pull off the lower cover, put your camera phone on record and while you are driving move the camera around under in various areas and then stop and play it back and see if the you can find the source from the recording playback?
T
teddybear
Remove radioactive material and re-test
Have you emptied your glovebox to rule out something rattling around in there?
Sound comes from under drivers dash. like down by steering column there abouts.
HiHoeSilver
Away!
Chicago
There's a big power block down there with a bunch a harnesses plugged in. Unplug then one by one and inspect for signs of arcing. Use a little dielectric grease on them and plug them back in firmly.
OR....
how's your HVAC system working? Try hot and cold on all vents and report back.
T
teddybear
OR....
I will try it.
T
teddybear
will try it.
BC
will try it.
Haha....feel your pain!!!! My 08 Yukon has done something similar for years. Kept hoping whatever it was would just give-up and then would be able to determine source as I dont feel like going under the dash. Like teddy said, I think mine is HVAC related because I have got it to stop when changing defrost/vent selections, almost sounds like a regulated HVAC pressure valve that is "hunting". Mine also sounds like the noise also comes through the audio system I presume from the chime and warning system maybe.
Leo1103
My '12 does it on startup, I'll see if I can grab a video. It almost sounds like lifter tick but its more sporadic, less consistent, and not rpm dependent.
I had a similar noise in my 02. Turned out to be the mode actuator, which is the super hard one to replace on that model.
Leo1103
Sorry for the potatoe cam, front camera turned on for some reason.
petethepug
Michael
SoCal
Supply fan motor to hvac has toasted bearings. If installed, clogged cabin air filter or an obstruction in the hvac ductwork or flap gone wild.
It sounds rotational and spinning off axis. Order an automotive stethoscope on the cheap from China Freight.
Jolly Roger
You are definitely not alone! I have the exact same "Gieger counter" noise coming from under my dash somewhere and its driving me batty!
I had a Jeep Wagoneer that the speedometer cable would make the same noise in the cable housing while it turned...hmmm
koomie98
