Garmin Mounting!?
PETEY
I got a new Garmin GPS for the hoe for my birthday. I was wondering if there is anyone who has one and how you have it mounted. I do not like the window mounting set up that it comes with and the wire is exposed. I would like to have that disapear.
Any input would be appreciated. Thanks in advance!
NCSUTahoe
Raleigh, NC
I didnt have the Onstar, so I just mounted mine in the cubby hole. Great if you dont need to take it out. And it cleans it up a lot.
The wire just runs through the back and then I put the wire in the dash, and comes out to plug into the cig lighter. But I just saw they have a hardwire kit on Ebay for $25, so I would suggest that for a really clean look.
Anthony
2004 Tahoe LT (MA)
Westen MA
I had that set-up, but I have a back-up camera going into the cubby this week :) Anyone have another place to put the Garmin? I have a Hardwire kit too
NCSUTahoe
Raleigh, NC
PETEY
PETEY
Thanks NCSU! That is the look that i am going for.
NJ04HOE
Paterson, NJ
Anthony....
Id put it on top of the dash, right next to the A-pillar if you can find a flush mount that makes it appear built in..and run the hard wire through the dash. Or even better....if you could find an A-pillar mount, like some programmers.
Similar to....
http://www.edgeproducts.com/product.php?pk=93&pvk=282&pname=Chevy%2FGMC+Dash+Mounts&pvname=2001-2007+Chevy%2FGM+Dash+Pod
I would go with that option, for $45 bucks I wouldn't be scared to mess it up by modding it to fit the garmin. I'm sure it's possible to get it to fit and look good.
tom q
Modesto, CA
do a search. I posted pics and instructions on how I mounted my tomtom. I also used the cubby
Xav8r
Greater Sacramento
For you guys that have done this where the onstar lived ... how are you securing the GPS unit into that spot. Forgive my ignorance, however I've never attempted anything like this and figured this would be an easy first project to get started with. Thanks ...
rogue status hoho
http://www.tahoeyukonforum.com/forum/showthread.php?t=10614
Go to radio shack and buy a female cig adapter with red and black jumper cables on the other end of the chord. It costs.. like $9.. cut off the jumper cables and wire the positive end into a fuse that is used when the ignition is turned over and then ground the negative end to a bolt close to the fuse box. Exactly what I did... takes up none of your cig lighters and is completely hidden. check it out
BobMc
OK--
I've looked--
Where does one find a switched power source in the interior of an 09 Tahoe?
Thanks!
Bob
BobMc
I'm on it.
Thanks--
I was not aware that there were any open slots in the 09 fuse pannel.
Thanks!
Bob
LilAndy
Orange, Tx
---------- Post added at 04:03 PM ---------- Previous post was at 04:02 PM ----------
can you post soem pictures of this because i would like to do this with mine thanks
RobK
