Fuel/oil pressure issue
jasonanh
Long post but want to get as much info on here as I can. I have a 2010 Tahoe LTZ 4wd. A couple weeks ago while running around town the Tahoe started to stumble really bad like it wasn’t getting fuel. Limped home with a check engine light on. Checked codes with scanner and got P018B, P069E and P2635. All of which leads me to fuel pump/pressure issues. The next day I turn on the Tahoe to move it to start inspecting and I notice I have ZERO oil pressure on the gauge at the dash. I open the hood to feel around and see how big a pain it is to replace the oil pressure sensor and find that the 3 wires to the connector are all broken. I removed the intake and repaired the wiring. Reassembled everything and have good oil pressure at the dash. Also, I no longer have any stumbling fuel issues and after clearing the codes and driving around for an hour I do not have any codes. Additionally my power liftgate is working again which I thought was a separate issue. My question is, does the electrical circuit for the oil pressure sensor tie in with any way to the signal or ground wires of the fuel system or power liftgate system or any other system for that matter??? Hoping a more experienced mechanic might have seen this before or know the electrical I was describing. Hoping that I fixed all the issues by repairing those 3 wires to the oil pressure sensor but don’t want to just assume that’s it. Thanks!
tom3
Not sure on your machine but sometimes a three wire oil sensor is used as a backup for the ECM fuel pump operation. But could also shut it down when showing zero oil pressure. But they sure didn't make it handy to get to back there for sure.
Fless
Moderator
People's Republic of Colorado
It's likely that the shared 5V reference signal from the ECM was shorted by the wiring issues at the oil pressure sensor. That would affect every sensor that shares that reference voltage.
The OP sensor is shown in the second diagram at the link below, using the shared 5V1 reference.:
J
jasonanh
Yeah not handy at all. As soon as I reached my hand back there and felt that the wires were broken I knew it meant I was taking the intake manifold out lol
Welcome to the Forum from NH.
Pics of the truck, please. If we can't see it, it does not exist.
Personally, I believe that you solved your issue, but I would recommend still looking for trouble codes for at least the next 5 times that you take your truck out of the driveway. I'm doing that, myself, after getting stranded 80 miles from home, due to a bad ground connection (I believe).
strutaeng
Dallas, Texas
Any e
No idea honestly. They were all a pretty clean break.
Any evidence of vermin, rats or mice? Those suckers (mother fu@$&ckers) have sharp teeth!
I had a rat get in my detached garage years ago and chewed thru all kinds of stuff. Air compressor air hoses, 5 gallon paint buckets, brand new EXPENSIVE welding leads, electrical extension chords, washing machine water supply lines (twice!) I still occasionally find stuff that was chewed thru when moving stuff around.
It was expensive and infuriating. Finally killed it after finding in the garage wondering sluggishly after injesting rat poison.
J
jasonanh
Charli1964
