It has a level kit yes front and rear. Keys are turned up have more bolt in on one side than the other. But it still could use another inch in the front to match the rear. That's why I got some ford keys but was told I'd need a diff drop to get what I want.
Again, read my post about using the Ford keys above.
Lifted Ford keys WOULD allow you to crank them up more, but there are bumpstops preventing them from moving those A-Arms further than what your Chevy keys can. The only reason I got the Ford keys was that the same E-bay seller had them with other parts I needed, he combined shipping, and they were almost $10 cheaper than the same Chevy keys.
THE ONLY REASON.
And I may end up turning them down a bit, just so I can have SOME downward suspension travel. As it is, it rides rough, but I don't mind it.
There are only TWO ways to get your truck level, if you already have front keys:
1) take out your rear lift spacers, and replace them with ones that are the same as how much you want to lift your current front to. You'll drop your rear to match the front.
OR
2) Get a true suspension lift, one that WILL drop your front differential, and change mounting points and angles of everything on your front end, allowing you to DRIVE SAFELY.
Think about it. Would you try to half-ass lift it, making it potentially UNSAFE for your wife and kids to be passengers in?
I know what my answer is. What is yours?
