Fluctuating voltage gage
Dixieman
Fluctuating voltage gage, sometimes at 14 then drops to 12. Do these alternators charge as needed or should they be charging 14 + all the time.
D
Dixieman
Thanks for the replies. sorry for the double post. cannot figure out how to delete.
2011 tahoe ls
me88
Germany
The ECM controls the alternator output, there are 6(!) different charging modes that the computer chooses from depending on temperature, electrical load, headlights on or off, ...
D
Dixieman
Guess I need to check battery cables and starter. Sounds like weak battery most of the time when cranking even with new battery
Cantrepeat
Sweet Home Alabama
I'm under the impression that newer alternator/charging systems actually shut off when the power is not needed. Thus, the gauge will show 12v or lower and when on show a normal 13-14v.
Scoots
My 2012 Tahoe is also between 12-14+ I noticed on a road trip so replaced alternator since the Tahoe has 98,000 on it
After replacing for the first 10 min 14+ then dropped again to 12-13 for a few minutes?
Scoots
Was this confirmed? That would be great
Thank You
Mistehkins
