Flaring shifts and slippage after HD2 shift kit.
Auzzie635
Long story short I have a 05 Tahoe 4x4 with 200,000 miles everything original. I plan on doing a cam in the future so I wanted to do a little preventive upgrade to the trans before sending any additional power through it. First owner was a older couple, my best friend bought it at 138k, then I took over the payments after about 10k miles so it has a known history and has not been abused much.
The actual install went relatively smooth, no issues installing all of the valves and actuators in the valve body, no issues adding springs/shims in the accumulators, and no issues rebuilding the 2nd gear servo and installed with the 2 gold shims installed with the kit and confirmed the band still had play by moving it with a screwdriver.
Assembly went fine and took it for a test drive and it works perfectly fine under light throttle although the shifts still feel stock despite having 2 shims in the 2nd gear accumulator. Around 30% throttle the 2-3 shift will start flaring and will be worse the more throttle used. The 1-2 shift is more positive but will also flare if on the throttle around +50%. I assume the 3-4 shift is similar but no need to test because in 4th on the highway under maybe 25% load will just start slipping. All other gears when engaged will hold up to 50% throttle but I have not felt the need to get on it just to see if they slip and wear the clutches and band fire no reason.
The only lead I can think of is there may be small leaks between the valve body because the gasket between the transfer plate and the case was stuck pretty bad to the plate and I had to use a flathead screwdriver to scrape off stuck gasket. Because of that there are some scratches on the plate and some small gasket remnants that you could feel with your finger but are very minamally raised.
Also one of the check balls were stuck in the transfer plate so I popped it out and very gently hammered the blown out hole back just a little bit but probably not enough.
So my issue is I don't thing tower those small of issues don't seem like they would have that large of an effect on the line pressure/flow rates. Is the trans just that sensitive to small leaks to basically barely hold gears and shifts? All other parts of the kit went together perfectly so those two things are the only problems but my gut tells me if I tear it apart and put in a new trasferplate and gaskets nothing is going to change and I'll have dumped $70 in fluids and gasket for nothing. So give me ideas or judge my logic because right now I'm stumped and am not sure where to go from here.
Linked video is an approximately 30-40% throttle pull to show shifting characteristics (I immediately let off the throttle after the 2-3 flare that's not it positively engaging third.)
Welcome to the Forum from NH.
Pics of the truck, please. If we can't see it, it does not exist.
I cannot personally assist you with your issue, but other members of this Forum much more knowledgeable than me in this area, like @NickTransmissions , will chime in.
NickTransmissions
Sin City
The transmission bench
At 200k that unit is due for overhaul and I wouldn't waste any more time w/it especially if the engine is or soon will be putting out more power. More than likely, your forward drum is leaking at the base of input shaft at the 3-4 clutch apply circuit conduit that flows from the shaft into the drum to apply the 3-4 clutch apply piston when shifting from 2nd to 3rd gear.
This assumes you installed this shift kit correctly, following all proper torque specs for the fasteners and didn't cut anything like gaskets, etc along the way.
I am also assuming you are talking about a 4L60E, not a 4L80E. If the latter, the HD2 kit is the absolute last kit I would ever install into one of those transmissions.
My first and only step diagnostically would be to thread in a transmission line pressure gauge and take it for a test drive - see what the pressures are when it flares, especially when hot. That will tell you if there's a cross leak at the base of the shaft as there wouldn't be any at the valve body, if the kit was installed correctly and everything else was done right.
alexblagoev
Member Recommended
