davidortenn79
- Joined
- Oct 19, 2025
- Posts
- 6
- Reaction score
- 3
I have a 2015 GMC Yukon XL, 5.3L, push-button start, and I'm trying to diagnose an intermittent electrical problem rather than just throwing parts at it. I'm especially interested in hearing from anyone who has experienced the same combination of symptoms on a 2015–2020 Yukon/Tahoe/Suburban/Escalade.
The problem has been intermittent.
At different times we've experienced:
I have not assumed that all the events necessarily have the same cause.
Battery is an AGM rated at 850 CCA and is less than a year old.
Battery tester results:
So the battery itself appears healthy.
Full all-module scan found several stored/intermittent codes. The ones that seemed potentially relevant were:
The P0513 and U0020 were not failing at the time of the scan; their current-cycle tests showed passed.
There were also several unrelated lamp/key-fob/etc. BCM codes that I haven't assumed are part of the main problem.
Both battery terminals are mechanically tight.
I voltage-drop tested the actual battery post against its clamp while cranking:
Those seemed very low.
I also removed the negative clamp and thoroughly cleaned both the battery post and inside of the terminal with an actual battery-post/terminal brush, then reinstalled it tightly.
The negative battery cable has two branches that I can physically see:
For testing I attached a temporary reference wire at the battery-side negative cable/clamp connection so I could safely reach it while measuring underneath.
I measured from that battery-side negative-cable reference to the engine-side negative cable ring terminal itself while starting the engine.
I videoed the meter because the display moved too quickly to read reliably in real time.
Tests have shown approximately:
So cleaning the battery post/clamp did not materially change that measurement.
For disclosure, these were normal start/crank events where the engine was allowed to start — I did not disable fuel to produce a prolonged steady crank.
There were two aftermarket accessories installed years ago — a deer-alert device and a USB charging port — powered through an add-a-fuse on a switched underhood circuit.
I noticed abrasion/exposed copper on part of that aftermarket wiring, so I removed the entire fuse tap, restored the factory fuse, and verified both aftermarket accessories are now completely unpowered. I'm leaving them disconnected while diagnosing this.
I'm deliberately not stating what part I think is bad, because I'd rather not bias the answers.
Has anyone with a 2015 Yukon/Tahoe/Suburban/Escalade experienced this same general combination of:
slow/intermittent crank + theft-deterrent messages + module/radio resets + dash electronics briefly dropping out + at least one complete no-start event. A few days ago the Yukon would not start at all. After sitting for a few minutes, it started normally, but then displayed the driver-window reset/relearn message telling me to lower/raise or open/close the driver window.
If so:
I'm interested in measured/confirmed fixes, especially if you've dealt with this exact generation, rather than guesses based solely on the theft-deterrent warning.
- “Service Theft Deterrent System” on the DIC.
- Some starts where the engine cranks unusually slowly/hard, almost like a weak battery.
- At least one occasion where it initially would not start, but after shutting everything down/opening the door/waiting briefly, it started normally.
- My wife has experienced the same slow-crank + theft-deterrent behavior.
- While driving, the dash/center electronics have briefly blinked off and back on without the engine stalling.
- After one event, the radio was reset to 87.9 FM/static, the DIC wasn't on its normal MPH screen, the clock was wrong/reset, and it displayed “Action Required — Open Then Close Driver Window.”
- Outside temperature also briefly displayed incorrectly and later corrected itself.
- A few days ago the Yukon would not start at all. After waiting a few minutes, it started, but afterward displayed the driver-window reset/relearn message requiring the driver window to be cycled.
Battery testing
- 12.77 V
- 100% health
- 100% charge
- 981 CCA measured
- 2.52 mΩ internal resistance
- Cranking test: GOOD
- Minimum cranking voltage: 11.25 V
Scan results
- ECM: P0513-00 — Immobilizer Key Incorrect
- Radio: B1325-03 — Control Module Power Circuit Low Voltage
- Steering Column Lock Control Module: U0020-00 — Low Speed CAN Bus
- HVAC Controls / Radio Controls also had historical B1325 high-voltage codes.
Battery-terminal testing
- Positive post → positive clamp: about 5 mV
- Negative post → negative clamp: about 8–10 mV
Ground-side testing
- one going to the engine
- one going to the chassis/frame
- first test: around 1.8–1.9 V peak
- test directly on the metal engine-side cable ring terminal: around 1.6–1.7 V
- after completely cleaning/reinstalling the negative battery terminal: approximately 1.64 V again
One other thing I eliminated
What I'm trying to find out
If so:
- What ultimately caused yours?
- What measurements or tests actually identified it?
- Was the failure visible when the part was removed, or did it look normal?
- Did the problem recur after the repair?
- Are there any particular grounds, cable junctions, starter connections, fuse-block connections, or module power feeds on this generation that you would specifically test next?
