extended swaybar links w key and spacer lift
whitey hoe
I just finished putting on my cognito extended sway bar links up front and what a big difference from stock.2 1/2 keys cranked and 2 in spacers w z71 springs ,extended bilsteins.The ride was great but I kept noticing the front dive hard in corners and stiffness at different times but now w the extended sway links,it is a true cadillac,just fyi in case anyone has ran into those problems after a level lift
KEVIN GARRETT
thank you i am piecing together my kit now and could never find an answer if i needed to get longer links or not with just a level lift.
whitey hoe
whitey hoe
My rear sway links are in from eBay ,I'm curious to see if the rear of my Tahoe rides different w them on.They are for a 2-4 in lift for a jeep tj ,.The new ones measure about 1 1/2 In longer than stock ,way more stout
ATIII
Brighton, CO (Denver)
I'm running these, no complaints.
Warrior Products 800039 3" Rear Sway Bar End Link for Jeep JK 07-10 https://www.amazon.com/dp/B004JMFE88/ref=cm_sw_r_cp_api_GEupxbE7SM7JY
Justinj360
So if you have a 2" rear spacer lift would you just get rear sway bar end links that are 2" longer than stock?
HiHoeSilver
Away!
Chicago
Essentially, yes. The idea is to keep the sway bar level, so the length may vary a little. Guys have used them from a few other vehicles, or just ordered based on length. I think jeep ones are commonly the answer. Been mentioned in a few different threads.
Justinj360
Essentially, yes. The idea is to keep the away bar level, so the length may vary a little. Guys have used them from a few other vehicles, or just ordered based on length. I think jeep ones are commonly the answer. Been mentioned in a few different threads.
If it's a matter of keeping it level then probably a 1" longer end link would work for me then. Thanks.
