Extended starting. .
Pockets
West Ga
Ok guys twice this week I have had the Yukon take more that 5 seconds to start. It just spins over and then finally catches. It's almost like it is out of fuel... any thoughts or am I just crazy.
Thanks
Donnie Yukonie
Yates Caretaker
Im pretty sure the newer tahoe's use individual electronic Fuel injectors controlled by a regulator , they are known to be the second most common failure in the Fuel pressure system other than the pump .
I would check the Fuel pressure first and go from there
GM Customer Service
Michigan
Thanks
Hey there,
I am sorry to learn that you are experiencing an issue when starting your vehicle. I understand that you are looking for advice and I might not be able to give any technical advice but I would like to look into this concern for you. Private message me including a brief overview of the concern, contact information, VIN, exact mileage and preferred dealership.
Thanks,
Jennifer T.
GM Customer Care
AZSCTACO
Phoenix, AZ
Thanks
Fuel pump is going out.......same thing happened to me.
Physh1
I'd start with a simple fuel filter replacement unless it's been done really recently. Clogged filters can cause extended start times. Check fuel pressure as well since GM pumps are known to fail.
CEL?
Cameron
buckyalumn
Just got my 08 Yukon XL back from the dealer yesterday. Same thing was happening to my truck and they said the injectors were bad. Replaced all of them and I'm hoping that takes care of the issue.
GM Customer Service
Michigan
buckyalumn,
I am happy to hear that your vehicle is out of the dealership and your vehicle issue seems to be resolved. Please keep us updated if anything changes.
Regards,
Jennifer T.
GM Customer Care
Denali2007
