Escalade taillight issue.
Denalibro76
Good morning all. I’m having an issue with my taillights (LH) Escalade conversion was done about a year ago and now it’s acting weird. I only have signal lights, hazard, lock/unlock lights when I step on the brake and only on the LH side. I did have to replace a load resistor on that side due to corrosion. Just wondering if this has happened to anyone else? The wiring and plugs appear to be fine. The only other thing I can think of is the possibility of the trailer adapter that I used has gone bad?
can you clarify the issue, meaning what does work when you press the brakes?
sounds like you only have a left brake light and that the center & right side are out?
IF so there is like 3 fuses for the center & right side, check those one will be labeled chmsl
the center & right side are tied together electrically
Denalibro76
Denalibro76
So if my LH signal is on the light only blinks when my foot is on the brake. If I put my hazards on, the left hand taillight only blinks when my foot is on the brake.
Denalibro76
Denalibro76
The RH taillight is working fine as well as center one. All the lights in the back worked fine up until a couple weeks ago.
I would check your tail light wiring harness at the lights and at the junction connection under the bumper for water intrusion or corrosion.
sailflow
