BAWLin in WI
09 Escalade
I have a couple questions (I'm becoming frustrated and discouraged)
Recently I did some work (new front brakes, new CV axle, new wheel bearing hub) and while I was at it I switched the rear to Bilstein 5100 shocks. Looked like it already has new coil springs in the rear so I left those in. I had been getting that service suspension message so I decided to go with the swap. Front has already been done prior to me purchasing vehicle.
Anyways, I snipped the connector to old air shocks and wired a 3.9 ohm 25 watt resistor into each side. I still get the service suspension message. It annoys me. Did I forget to do something?
Another question I have is regarding stance of vehicle. Thought after putting in New rear shocks I'd lose the rear end sag. It still appears to be sagging the same as before I switched. Can some one measure their stock setup from ground height to bottom of hitch receiver and possibly ground to center of the bottom of the front bumper cover?
Pic attached
Thanks
Sent from my LGUS997 using Tapatalk
Pic attached
Thanks
