Epic Road Trip AAR - 6,000 miles towing 10,000 lbs
intheburbs
SE MI
Follow-up to my tow vehicle cooler upgrade thread - HERE
Finished a 20-day road trip to Utah and Yellowstone. By the numbers:
6074 miles total driven
Total weight 16,600 lbs, with an additional 500 lbs of adult kids for one long pull.
Ambient temperatures as high as 105°
Multiple Continental Divide crossings, including the Eisenhower Tunnel (11,100')
Daily mileage averages anywhere from 5.8 MPG to 8.0 MPG, depending on wind, conditions, etc
Transmission temperature never went over 180° (previous trips went as high as 243° with lighter trailers)
Engine temperatures frequently in the 230°-240° range when pushing it hard
One "Engine hot turn off A/C" warning
Oil life monitor went from 56% to 11% in one day of particularly harsh towing
2 oil changes done (based on OLM)
Ran out of gas once - after using 30.0 gallons, I think my secondary fuel pump died (had two full 20L Gerry cans on board, so minor inconvenience)
Engine is slowly losing coolant - no obvious leaks, maybe a pint after 600 miles of hard towing, negative coolant CO2 test (thankfully)
Evaporator is icing up after 10-15 minutes on A/C or defrost - have to check for leaks or other issue
Overall, pleased with how the truck performed. No major issues, some minor ones I had to deal with. The engine is losing coolant. Everything is dry, no apparent leaks. After a long day of driving, I had to add 10-16 oz to the overflow tank. To be safe, I grabbed 6 jugs of premixed Dexcool at the first Walmart. Ended up using about 1.5 jugs over the whole trip, including an initial quart and a half for the first topoff.
A/C evaporator is icing up. Gotta get my mechanic buddy to figure out what's going on. At first we thought it was because it was 98° and 95% humidity in Illinois, but it continued to ice up the entire trip, including when running the defroster with ambient temp in the low 60s.
Ran out of gas once. Still a very disconcerting feeling - hitting the gas and nothing happening. At first I was afraid the transmission gave out. Computer said exactly 30.0 gallons used. I'm wondering if my secondary fuel pump died. The primary was preemptively replaced last year. Letting it run down again to see exactly when I'll run out of gas, to verify a dead secondary.
Got to use my battery jumpstarter twice. I'm constantly amazed how unprepared and clueless people are about their vehicles.
This might be our last trip using the Suburban as tow rig. We're seriously looking at big-ass fifth wheel trailers, and I'll probably be picking up a 1-ton dually. Late-model Ram with the ** (LOL - apparently abbreviating High Output is bad) Cummins is probably at the top of the list. I'm approaching retirement, and our initial plan is to full-time about half the year doing the Snowbird thing.
On with some pics:
The rig:
Outbound/loaded weight with just two adults, 500 lbs of 3 adult kids joined us later
Easy-peasy through Illinois and Missouri:
Kansas got a little toasty:
Working hard in heat and headwinds:
Boring, typical Colorado Front Range sunset
Required stop (and cheapest gas)
Highest point in the country on the US Insterstate Highway system, 11,100':
Another crossing:
SW Utah!
Wife taking in the view:
The Road Less Traveled - Cathedral Valley Drive at Capitol Reefs - didn't see other humans for 6 hours:
Desolation in Utah:
Zion:
Local fauna watching cars:
Bryce - no words are sufficient
TPS apparently only transmits two digits. Tires were set to 80 PSI cold. Computer was confused. LoL
At Yellowstone/Old Fairthful - my son, the Ranger:
Bought him a souvenir:
Beehive geyser erupting:
Lake Yellowstone:
Friendly neighbor at Fishing Bridge RV Park at Yellowstone:
Obligatory Yellowstone traffic jam pic:
Easier towing back home:
Desolate part of I-90
PPK_
Oklahoma City
i did get about 8 mpg towing a 6000 lb trailer with a 5.3... same trailer with a 1500 and a 3.0 was 9 mpg. you don't get much mpg when you tow a real rig behind you! That tow was in the NM area.. hills are always a treat..
j91z28d1
I would guess you have a pin hole in the rad that drys before it can be seen. especially if it's an old radiator. I'm pretty sure mine is doing that.
if these have the variable ac compressor, I had one is a 4th Gen camaro that the pressure control valve got stuck and would freeze up. around town it was fine, on the interstate I'd have to cycle the ac switch. I once put gauges on it, and on the interstate driving I saw the low side get down blow 20. I never fixed it, but ackits.com sold the valve, it was a snap ring on the side of the compressor. you had to empty the system, remove the snap ring and it just pulled out..
if it's a cycle style compressor, disregard all that lol.
alexblagoev
