Engine Tag
SCiesie154
Can someone explain the alphanumeric information on my engine tag. Two photos of the same tag. Thanks in advance!
Z15
Michigan ,USA
JW6 is the Broadcast Code. It would linked to specifications in the system. Rather than a long part number its assigned a broadcast code JW6. Theoretically several iterations of part number could have the same broadcast code, They use broadcast codes in assembly processing language instead of part numbers.
DenaliRoyal
