Engine dies over bumps, but also revs uncomanded
michaeljoe
I need help diagnosing my 04 yukon, it dies going over bumps (I live 20 miles down a washboard road) and when it dies the door locks disengage as well. Sometimes, at idle speeds, it will also raise rpm slowly, even to the point of shifting into second gear, without my foot on the gas pedal.
Theres a heavy power draw when i use the windows the lights dim and the engine drops revs.
I tried replacing the ignition switch and ignition lock, neither helped.
Ground wires seem secure.
Everything looks good so far as I can see.
Thabks in advance for any help!
Fless
Moderator
People's Republic of Colorado
Look up "voltage drop test" on YouTube and do one for both the positive and negative systems. The main cables rot from the inside and that's not something one can determine visually.
Also have the motor mounts and tranny mount checked to verify that they're still restricting engine rotation appropriately.
justirv
Also check out the "Big 3" (or 4) grounding solution upgrade (search). I find that it takes care of many electrical gremlins.
Mariam26A
