Trying to remove my ecm and abs system completely from engine compartment. I have gone carbureted, th400 np 208, and straight axle conversion so they really don't do anything for me anymore. I am trying to clean up the wiring harness or even just start over. If anyone has any good info on the locations of key wires like fuel gauge signal wire or vss signal to the gauge. I have had the engine running without the ecm plugged in and other than no fuel gauge/ speedo everything works. I have located the Tach signal wire and engine temp gauge wire already. Any info would be greatly appreciated or if anyone knows somebody building custom harnesses that would be a life saver.
