Dual Alternator wiring?
Simen Hagen
Norway
Hello
I'n about to do a dual alternator setup.
I will be running the second alternator on it's own to charge batteries in the back.
Alternator is a 253A internal regulated.
My question is the wiring of the plug. Am i correct with connectin the L terminal with a 470 Ohm 1/2 watt resistor to ignition switch, and I/F terminal to the 12v output on the back of the alternator? Or do i need to Connect S terminal somewhere too?
The stock system only has two wires on it.
Thanks in advance.
MyCleftNut
