Forgot to update…
Took the timing chain cover off and then blew 6hrs of battling the chain off, finally got it after having to buy some cheap, thinner pry tools.
Took out the original cam and on lifter 8, there’s a chip! Not sure if it was from the original problem or if it’s new from the mist matching cam/lifters so I’m going to order new lifters and pull the passenger head.
Hopefully I can buy 1-2 individual lifters and 1 head gasket from BTR (also head bolts).
I also need to buy a new fuel rail set ffs!
All in all, it’s moving along. I’ll probably have time on Tuesday so take the head off and confirm a good or bad lifter on cylinder #8.
I also couldn’t get passed using metal rods to hold the lifters, instead I picked up a pair of 36” 5/16 wood dowels, worked like a charm.
Radiator is already back in, pita to pull it out but was a breeze to put back for some reason.
If you look closely, you can see slightly thicker blue oil marker marks behind the green laser. Top of the block all the way down. I found it easiest to mount my laser on the garage header as leaning on the truck makes the laser bounce.
