DRL only work when jumped 01 Yukon
Dvdtactical
Need DRL to "function as intended" to pass safety inspection. Fuses and relays seem to all be ok. DRL only come on when jumped at relay in under hood fuse box.
Fless
Moderator
People's Republic of Colorado
Likely the ambient light sensor on the dash. But put a capable scanner on it to see if that function is working correctly in live data.
For replacement, see the link below but use the links at the top of your browser to find the similar site for your vehicle, if that's not it.
Same vehicle, electrical diagram:
D
Dvdtactical
Thanks for the diagrams. Headlights turn on and off when sensor is covered and uncovered. Will hard wire DRL to key on circuit to pass safety inspection.
if you need to verify and do not have a helper or reflective surface, you can chock the wheels, put it in reverse and get out and look.
Woned2004
