Welcome to the Forum from NH.
Pics of the truck, please. If we can't see it, it does not exist.
I cannot personally assist you with your issue, but other members of this Forum much more knowledgeable than me in this specific area will chime in.
While we are awaiting input from other members of this Forum, I asked Grok about your issue, using your own words, and this is the reply.
Yes, other 2021 GMC Yukon (and related Tahoe/Suburban/Escalade) owners have reported similar problems, though the exact combination of dead driver-door panel controls (windows + memory seats) plus both “Service Door Latch System” and “Service Driver Switch” warnings is not the most common single complaint.
What’s been reported
- “Service Door Latch System” has shown up on 2021 Yukons. One owner of a new 2021 Yukon posted in 2022 about ongoing door-locking problems and that exact message; the truck spent weeks/months at the dealer with no lasting fix at the time. A later reply noted a similar issue on a 2022 Silverado.
- Later (especially 2025+) models have a well-documented version of the same message (GM preliminary information PIT6288 series). It is frequently caused by the electronic rear child-safety locks getting out of sync between left and right doors (or with the body control module). The fix is often a software/calibration update plus a specific on/off cycle of the child locks through the correct infotainment path (Controls > See More Controls > Doors & Windows > Child Safety Locks). Some early 2025 GMC models also needed a radio reprogram so the on-screen buttons would work while the error was present. Physical issues (binding inside door-handle cable putting preload on the latch) are also mentioned.
- Driver-door master switch / panel failures (windows, locks, mirrors, and the memory-seat buttons that live on the same panel) are a known wear item on these trucks. When the whole left-side panel goes dead, it can trigger related service messages and interrupt memory-seat functions. Separate memory-seat module software issues (TSB 21-NA-131 / earlier PIT5796) affect 2021 Yukons and can cause limited or no seat movement, failed memory recall/easy-entry, and “Service Driver Assist” messages; the fix is usually a reprogram of the driver seat adjuster memory module rather than parts replacement.
Your dealer’s statement that “it’s on a bulletin” and that they can currently only reset it lines up with how GM has handled these intermittent software/sync and module-communication issues—resets or temporary clears are common while a permanent calibration or hardware fix is refined.
Practical next steps
- Ask the dealer for the specific bulletin number(s) they are referencing and whether any module reprogramming (BCM, radio/A11, driver-door module, or seat memory module) is available beyond a simple reset.
- Have them check for diagnostic trouble codes related to the driver door module, window switches, door latches, and communication (common U-codes for lost communication with door or seat modules).
- Confirm whether individual passenger-door window switches still work (helps isolate a master-switch vs. wiring/BCM problem). Wiring in the door jamb/boot can also cause intermittent total loss of door functions.
- If the reset only lasts a short time, push for deeper diagnosis of the driver door switch assembly itself or related harness/connectors.
These issues are annoying but generally not immediate safety hazards if the doors still latch and open normally. Keep documenting visits and symptoms in case it becomes a recurring problem under warranty. Many owners eventually get a lasting fix once the right software or a switch/latch is addressed.
