Drive Line Vibration
2015 YDXL 4WD
New to the group. I have a 2015 Yukon Denali XL 4WD with just over 220,000 miles on it. It has the original 6speed transmission, transfer case and front and rear differentials. All have been regularly serviced and maintained with fluid changes. I have recently just started to get a strange vibration that seems to be coming from some where in the driveline at highway speeds. It will come and go even with the cruise control set. Its not a tire vibration as it rides smoothly and there is no shake in the steering wheel, I know a rear tire wouldn’t cause steering wheel shake. I have checked the drive shafts front and rear and they are tight with no play and no leaking. The transfer case shifts through auto-trac, 4hi, 4lo, and back to 2hi with no issues whatsoever. The 6peed shifts without any issues. I did some research and have found that a transfer case with this amount of miles could possibly have a
“stretched chain” and the vibration could be coming from that. Has anyone experienced this type of issue? What was the culprit? Any help would be greatly appreciated . Hopefully I posted this correctly
Welcome to the Forum from NH.
Pics of the truck, please. If we can't see it, it does not exist.
I recommend that you take the truck to a trusted local repair shop, and get the truck on a lift with the wheels off the ground and with someone inside the truck. Put the truck in gear and press the gas pedal and get the drivetrain up to speed, and see if you can re-create the vibration situation. If the vibration occurs, then the Mechanic underneath the truck can go around, both visually and with a stethoscope if necessary, and locate the source of the vibration.
OR VietVet
GMT800 2005 Tahoe Z71
Navy Supporting Member
Willamette Valley
Welcome to the forum, from Oregon.
After what you have said and guessing at a driveline vibration, I want to know hoe you came to that conclusion. Feel the vibes where? Seat? Floor? Only when maintaining highway speed? Ever in the steering wheel? Move the steering wheel slightly to one side or the other and changes vibes feel?
I would be swapping tires, front to rear and see if feel a change? Suspect the mounts.....etc.
2015 YDXL 4WD
2015 YDXL 4WD
Thanks….
Some pictures of my 2015 Denali
2015 YDXL 4WD
2015 YDXL 4WD
Thanks….
I never feel it in the steering wheel. In the seat like it is coming up throughout the floor board. Can feel it from the front seat, middle seat and third row seat. From the front seat it feels more to the back.
Some pictures of my ride.
Charli1964
