th3 shifty
Hey guys I just did the MPFI injector change last week and got it all together. I also changed the following:
Spark plugs
Wires
Cap/rotor
Intake plenum gasket
Coil and ICM
Started up the truck (96 tahoe) and started out with a really high idle, I quickly found that to be a vacuum leak from the new injector to plenum gasket area and solved it. Cleared the code started up the truck, starts as a high idle then drops to 800 and maintains. Soon after that I quickly get the P0300 code.
I have a foxwell scanner and hooked it up and found the followingsee pics)
Now I’m not good reading fuel tables are pretending to know what half this stuff is, I DO know that -22 spark advance at idle is wrong, and the motor is pulling timing to pull down the idle.
It’s only throwing 1 code, I have soaked that motor down with carb cleaner to try and find another vacuum leak but I have found one.
Any help is appreciated
Spark plugs
Wires
Cap/rotor
Coil and ICM
