Disclaimer: Links on this page pointing
to Amazon, eBay and other sites may include affiliate code. If you click them and
make a purchase, we may earn a small commission.
Have a couple loose wires and vacuum lines just trying to figure out what they go to so i can fix em. The unhooked wire connection is by the firewall. Any ides will help thanks.
Are you throwing any codes? Vacuum lines must be hooked up properly or plugged. See if the wires are hot or not with a volt meter. Not enough information to help. Are certain things not working, that should be working? Unplugged vacuum lines can make your engine run lean...not good at all! or they could just affect your heater or other accessories that don't really matter if they have been capped off.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
