Tahoe97
- Joined
- Aug 27, 2013
- Posts
- 90
- Reaction score
- 75
My first and only Tahoe 4x4 4 door LT w/244k miles on it, purchased new in October, 1996, has just become disabled due to what I believe to be a failed transmission sun gear shell based on the symptoms of hesitation/delay in shifting out of 1st gear and a completely inoperable reverse gear. This just happened this afternoon as I was fortunately returning home. I have not decided whether or not I will invest in a tranny rebuild or just sell it as is and move on. If anyone on this forum has this generation Tahoe, needs another to source parts from, and is interested in acquiring mine, let me know. Thanks!
From AI
On a 1997 Chevy Tahoe 4x4, if the transmission hesitates to shift out of 1st gear and there is no reverse, what transmission problem is this indicative of?
2 hours ago
Why these two symptoms together matter:
From AI
2 hours ago
Claude responded: This points to a worn or broken input sun gear shell (commonly called the "sun shell") in the 4L60E transmission — the automatic used in the '97 Tahoe 4x4.
This points to a worn or broken input sun gear shell (commonly called the "sun shell") in the 4L60E transmission — the automatic used in the '97 Tahoe 4x4.Why these two symptoms together matter:
- The sun shell is a thin-walled part that both 1st gear and reverse rely on to transmit power through the planetary gearset.
- It's a known weak point in the 4L60E — the splines are prone to stripping or the shell itself cracking under load.
- When it fails, you typically get exactly this combo: hesitation, slipping, or delayed engagement going into 1st, plus a complete loss of reverse, while 2nd through 4th (and sometimes drive overall) still work relatively normally.
