Disclaimer: Links on this page pointing
to Amazon, eBay and other sites may include affiliate code. If you click them and
make a purchase, we may earn a small commission.
is this where my sub is located in 2000 denali?
also, is it hard to remove the 6 disc cd changer in the console and can i plug something els into the cd cable to use?
In the 00-03 models I think it’s in the driver side rear panel. You should see like a speaker spot above the tire jack. 04-06 models are in the console.
should be drivers side rear behind the rear wheel well you will see the plastic speaker grill holes, that looks like an OBS so not entirely sure, my 2000 was a NBS
FYI, you keep posting all your questions in the NBS (2000-2006) section. You are going to have better responses to your OBS if you post in the 1991-1999 section.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
