Custom jumper cables
Electrician
I wanted to show my custom jumper cable set-up. Anderson plug next to my Ebrake release so I don't have to pop the hood and clamp onto my battery. Just open the door and plug in like it's an obd. Pretty nifty. I can jump somebody parked behind me with a battery in the trunk. Yeah!E1B918E4-05C0-45D1-A6C1-8E57A122C420.jpeg
justchecking
Military
SW Ohio
I wanted to show my custom jumper cable set-up. Anderson plug next to my Ebrake release so I don't have to pop the hood and clamp onto my battery. Just open the door and plug in like it's an obd. Pretty nifty. I can jump somebody parked behind me with a battery in the trunk. Yeah!View attachment 389857
Reminds me of the setup all the old army vehicles we drove had. That was real convenient in the cold.
mattbta
Frisco, TX
I've got a NOCO Genius that I use as a tender/maintainer and would like to do something similar but haven't figured anything out. They make a connector that has ringlets on the battery ends, but they don't fit well under our side-post connections. I bought some adapters thinking I could use them, but I couldn't make it work.
The plan was to have the hardwire connector up through the grill like @Scottydoggs mentions.
That is the same high amperage connector that I use to connect my second battery to the buss, if ever needed.
corvette744
2004 Z-71
Northern illinois
No more battery cables for me-i got this new portable jumper and im amazed at it.First tried the noco gb40,had to recharge 3-4 times a year.Why have it if its dead when you need it.Then tried this audew recomended from a freind.Wow so it sits under my 2nd row seats in the tahoe i have started 3 vehicles this winter already have not charged it and its at 70% still.This was when it was -30 out might i say.I bring it out on the water when im fishing and have used it many times out there for boats not starting. https://www.audew.com/Audew-20000mA...l-Engine-with-LCD-Power-Display-p-100058.html
OR VietVet
Multnomah Falls
Military
Willamette Valley
I used to have an off road rig that was built to go anywhere. It's name was BRUTUS! Anyway, I had it set up to be able to move my winch from front to rear if needed and had these hook ups for it. I have a couple of the portable jump stations too and just need to make sure they are charged up at all times.
Electrician
Electrician
Yes, the portable jump packs always sound great when you first get them. Then as days go by you tend to forget about having to charge it every now and then and it sits there next to the emergency roadside stuff in the back til the day you need it, plug it in, and all you get is crickets
RAMurphy
Bob
S. Maryland
I also have a portable (NOCO) and I love it and have used it to jump several cars. I've also used it to power some wireless speakers during my brother's grand daughter's birthday party - he forgot to charge them prior to bringing them to the park. Works great. As far as keeping it charged, easy enough for me - I'll plug it in to my charger on long road trips as required. Never had the charge drop to low where it wasn't useable.
snackcake01
