tkat79
Hi, really need help figuring out what's causing my vibration issue.
We just purchased this 24 Yukon Denali w/17.5k miles in September. About 2 weeks in, we noticed vibration issues and the bumps in the road seemed a bit rough and very sharp sounding. Nothing like our previous Cadillac. Had the dealer look at it, they couldn't find anything. They rotated and road forced the tires and told us see if that helps. On the vibration issue, it seemed to help for a few days then returned. On the bump issue, no help at all.
Fast forward about one month, with only 19k on the oem tires, after washing the vehicle, I noticed the tire tread looked very worn, as in little tread life left, and noticed a gash on the rear tire sidewall that looked like it had been there for quite some time. Took it to the dealer again, we all agreed the oem need to go. The dealer made us a deal on new Michelin tires, we accepted their offer and had them replace all 4. Of course hoping this would solve the vibration issue.
Unfortunately it's still there, in fact a little worse. The dealer now road forced the new tires, same issue. Nothing resolved. Also, want to add a little more information, the steering wheel has excessive play (in my personal opinion), a good 3 to 4" before the wheels respond to the direction the steering wheel is turned.
I attached a video of the vibration. You can also see the vibration in the head rests and you can visibly see the cluster screen shaking. You can feel it mainly in your seat bottom and back, and on floor boards. Very slightly felt on the steering wheel.
Any help or similar stories would be greatly appreciated.
T
tkat79
Has the alignment ever been checked and adjusted?
I bet the dealer didn't do an alignment. I'll ask them today and let you know. Honestly, at the point of making them take the Yukon back and buying a different vehicle, possibly from another dealer.
Tahoe14
Central Fl
Depending on the reputation of the Dealer hopefully they are doing everything they say they are. A second opinion may be warranted. The alignment may be the way to go. Good luck and nothing is more annoying than dealing with Dealers who can’t diagnose the issue and fix it.
ReaperHWK
Wow that’s pretty noticeable. I’d be very annoyed as well. Does it happen all the time or only at certain speeds? Did the dealer check all the bushings in the suspension? To eliminate thw trans/drivetrain could you put it in neutral while it’s vibrating to see if it goes away. Not sure if these new trucks will allow a neutral shift at 60mph nowadays though.
If the truck allows the neutral shift I’d suggest slowing the car to a full stop than shifting to drive again.
T
tkat79
Depending on the reputation of the Dealer hopefully they are doing everything they sat they are. A second opinion may be warranted. The alignment may be the way to go. Good luck and nothing is more annoying than dealing with Dealers who can’t diagnose the issue and fix it.
They have a good reputation and we have purchased 8 vehicles from them over past 8 years. This is the second time we've had an issue with one of their vehicles they acquired from Michigan. The other 6 had no issues, however they were either local trades or brand new. We have 10am meeting with them tomorrow to discuss trading the Yukon in on something else. I'll keep y'all posted.
T
tkat79
EDIT:
I tried switching to neutral while going 55, 65, and 75mph. At first I thought ok, seems better @ 55mph, tried again at 65 and 75mph, vibration continued to happen. The faster I go, the vibration seems to worsen. Mind you, brand new Michelin tires and road force balanced.
Happens pretty much at any speed, of course the faster, the more noticeable. Thank you, I'll try what you said and shift in to neutral, see what happens, then slow down until stopped before putting it in gear again. Great idea! We're likely going to trade it back in tomorrow but it would be nice to know if it's the trans/drive train before going back tomorrow.
T
tkat79
Took the Yukon back to the dealer this morning, they had another tech that hasn't worked on the vehicle on any of the recent visits take it for test drive. They said it's just the way these trucks drive and that most of what we're feeling is from the road surface and having 22 in tires. I call bs only bc I have driven other Yukons and Tahoes and trucks that have 22s, and they don't shake or vibrate at all. We also test drove a 27 Traverse RS while we were there today that had 22s, no issues with its driveability either.
We decided to take the Yukon to Discount Tire for a second opinion. Right away they found one wheel off balance by 7oz!! The other 3 were perfect. Omg! So needless to say, the vibration is now about 99% better. The bumps still feel harsh. I'm going to eventually buy some new 20 inch wheels or trade these 22s on Facebook. I think 20s will help greatly with the bumps in the road.
Thanks to everyone that chimed in and offered advice.
JoeBlobs
Senior Member
NJ
7oz is crazy. My first thought was a bent wheel so maybe you're heading in the right direction.
ReaperHWK
How was that road force balanced? Twice I thought you said.
T
tkat79
I think the initial time they road force balanced the new tires, Im thinking they forgot a wheel somehow or possibly side tracked during the process. The second time, fairly certain they lied about it. I still can't believe a senior tech test drove it and thought it was normal. Just wow.
T
tkat79
And…worn tires and gashes were not even mentioned by the techs? Wth
My thoughts exactly. Done with this local dealership forever. Sucks as they are 3 miles from my house and I really like our salesman. However, this situation is unacceptable and all trust is lost. 70k on a Yukon Denali and they claim that's just how they drive, c'mon.
T
tkat79
The vibration isn't completely gone, although much better, but there's still something that feels off. Im really hoping it's not a bent wheel, which the dealer also claims they checked on during the tire installation.
My brother in law has a 2024 Tahoe with 20s wheels. I plan to swap wheels with him this weekend and see if all the issues with my Yukon go away. If so, then yes, likely a bent wheel and the dealer will be replacing.
Im taking the vehicle to a local mechanic next week. Probably should have done this a while ago. I'll let you know how things go.
olyelr
Elk Rapids, MI
A bent wheel should be very easy to see while balancing a tire and wheel combo. But, judging by your past experiences with them, i wouldnt be surprised if they overlooked a bent one or even batted an eye to it.
That being said, a wheel can still cause vibrations even if it isnt physically bent to the eye.
I will be very curious to hear how it goes when you swap the tires/wheels out and go for a test drive. Willing to bet it rides like butter.
T
tkat79
Update:
Lost all faith in the dealership we purchased from. Took the Yukon to another GMC dealer, so far they found one leaking front shock, replaced it under warranty, found that all 4 brand new Michelin tires won't balance correctly, warrantied and replaced all 4, cleanup up wheels thoroughly before installing new tires, road forced balanced, and the vehicle still vibrates. Next they are swapping wheels with another Yukon. Next step if it still vibrates, calling GM specialist to diagnose.
ReaperHWK
Update:
Sounds like you’re in the right place now. Doing the common sense steps. Swapping with another Yukon is a smart move to eliminate and wheel and tire issues. Good luck.
West 1
I would pull a Car Fax on that rig to see if it has history you should know. Maybe something got bent in the drive train at some point?
Just to rule it out, with the car parked rev the engine to the RPM where it vibrates on the road. Any vibrations now would be engine related and not drivetrain.
Test 2 would be to drive to the speed where the car is vibrating. Slip it into neutral and see if the vibration is still there or gone.
My Escalade had 22” tires and no vibrations. My current Denali has 20” rims with zero vibrations.
Personally I like the 18” rims, the taller rubber tires seem to absorb bumps better. They give up some handling stiffness but you don’t hear of the rims bending and the tire protects the rims better from road rash.
Curious to see what you find in this rig.
Charli1964
