Last week I noticed coolant on the ground. It does not appear that any of the hoses were leaking so I replaced the water pump (vehicle as 190k miles so it was probably due for a new one anyway). After installing the new pump, I noticed a slow leak that appears to be coming from the thermostat housing. I installed a new thermostat when the new water pump was installed. To be honest, I am not sure that is not where the initial leak was coming from. I installed a new gasket when the new thermostat was installed. The thermostat bolts are torqued to the proper spec (in fact, they are a bit) more because when I noticed the leak, I tightened them down a bit more. I am hesitant to tighten them down any more for fear of snapping off the head. Any ideas why it would be leaking?
Thanks
Thanks
