Yes, there is conflicting information that dates all the way back to 2007. It's because when GM introduced dexron 6 with a service bulletin (04-07-30-037) it had a specific paragraph addressing transfer cases and transaxles. In that paragraph it says that if any vehicle was using dexron 3 in the transaxle or transfer case, it should now use part number 88861800. (Instead of dexron 6 basically)
So what is that part number? It is a 75w80 mineral based gear oil.
References:
The offending paragraph in the service bulletin from 2007:
So that's where all the confusion is. So do you apply the information from 2007 to your 2013, or in my case 2014 transfer case? No. That service bulletin came out when Dexron 6 was released to the market. You have to make the assumption that it hadn't been tested yet on transfer cases and transaxles, hence the statement. At some point after it's release, GM started using Dexron 6 in the transfer cases as the OEM specified fluid.
There is probably another service bulletin specifying this, although I have never been able to find it.
So I stick with Dexron 6 in the transfer case because that's what it came from the factory with. But you can see from the above where the debate originates. Keep in mind Dexron 6 was introduced almost 20 years ago.... I am fairly confident it went through further testing and evaluation for use in the transfer cases. I replace mine every 36,000 miles and currently have 188,000 miles on it with zero issues, using Dexron 6. I also use it in my 2003 Hummer H2 with no issues.
Without a specific service bulletin specifying its use in transfer cases since 2007 though..... Technically that does create an issue, and it's because of that there are those who insist on following the 2007 directions and using gear oil.
So while this doesn't definitely answer beyond a shadow of a doubt what you need to know, hopefully it paints the overall picture to consider.
