FrankU
New in unopened box after 6 week wait. Decided to g a different route. Spec's listed below. $ 475.00 shipped no waiting.
Brand: COMP Cams
Manufacturer's Part Number: 156-400-13
Part Type: Camshafts
Product Line: COMP Cams XFI SPR GM Gen IV VVT Camshafts
Summit Racing Part Number: CCA-156-400-13
UPC: 036584197553
Cam Style: Hydraulic roller tappet
Basic Operating RPM Range: 1,300-6,500
Intake Duration at 050 inch Lift: 210
Exhaust Duration at 050 inch Lift: 224
Duration at 050 inch Lift: 210 int./224 exh.
Advertised Intake Duration: 263
Advertised Exhaust Duration: 277
Advertised Duration: 263 int./277 exh.
Intake Valve Lift with Factory Rocker Arm Ratio: 0.556 in.
Exhaust Valve Lift with Factory Rocker Arm Ratio: 0.568 in.
Valve Lift with Factory Rocker Arm Ratio: 0.556 int./0.568 exh.
Lobe Separation (degrees): 114
Camshaft Gear Attachment: 1-bolt
Computer-Controlled Compatible: Yes
Grind Number: 263PHR14
Valve Springs Required: Yes
Quantity: Sold individually.
Notes: Must be used with COMP Cams phaser limiter. For use on models with variable valve timing without active fuel management.
Brand: COMP Cams
UPC: 036584197553
