Matthew Jeschke
I need some help... I told my buddy to come over and we'd take care of a few fixes he wanted to do on his 1999 Jeep Wrangler 2.5L cylinder with AX5 transmission and 180k miles. It's a sweet little jeep. Seems he had a few clutches done in the past and they never changed the throw out bearing, it was rattling quite a bit. We dropped the transmission and replaced the following:
Here's a few tests we have done:
Static Roll Test (PASS)- Test clutch release: Put transmission in 5th gear, push in clutch pedal, and roll Jeep by hand. Test clutch apply: release clutch pedal and Jeep can no longer be rolled.
Test throw out bearing (FAIL?): put a steering wheel puller in place of slave cylinder. Pushed in the clutch release fork / compressed the pressure plate. Over road the clutch safety switch & started the jeep. Won't let us into gear when jeep is started... although I think my friend gave up. He won't let me push the steering wheel puller in any farther.
Test release clutch release when in in 2nd gear: turn off jeep and put into 2nd gear. Apply parking brake, and push in clutch. Start Jeep. Starts fine. Then slowly release clutch pedal. Jeep stalls and turns off.
Test clutch release for neutral to any gear: turn off Jeep. Put into neutral. Push in clutch & start jeep. Keep clutch in, try to select any gear, transmission won't allow us to enter gear (w/o grinding).
- Clutch
- Pressure Plate
- Throw out bearing (new fork / lever to apply force)
- New slave cylinder (note original master cylinder)
- Sanded down old flywheel and reused it.
