Clunking
corvette744
2004 Z-71
Northern illinois
If everything is tight im going with upper steering shaft very common ask me how i no.You can lube it for free or replace it cheap
corvette744
2004 Z-71
Northern illinois
Lube what part?
Upper steering shaft if you remove the lower bolt and push and pull it up and down it should get enough grease on it to reinstall the bolt and go for a test drive.This will verify that is the problem without spending a dollar.You could take the shaft totally out and put grease on the shaft and check for play if you want to do it right but it will only last so long.Their is a revised updated upper shaft that is supposed to make this problem go away forever.Under 100 bucks oem under 40 amazon.If you do remove it make sure your steering wheel does not spin around or you will break the spring in the column-just put your seat belt threw it to hold it from spinning.
ckylec
