belair62
I read a few long posts regarding the Range module and emission tests but it seemed most were in PA or NY. Does anyone in Illinois or Chicago have any info on whether pulling the Range prior to test will cause a fail ?
pretty easy to tell by removing it then checking for the "readiness" with a scanner.I read a few long posts regarding the Range module and emission tests but it seemed most were in PA or NY. Does anyone in Illinois or Chicago have any info on whether pulling the Range prior to test will cause a fail ?
Dustin what issues did you see re-activating AFM ? I feel like i'm walking on eggshells with this AFM stuffThe Range device keeps the emission monitors from setting so for emission testing you’ll want to unplug it a week before you get tested. Careful with that though, in my experience the AFM system doesn’t work well being disabled and then re-enabled
I think I am going to send mine out to LT1 when I get back to town. As long as that process allows all monitors to set thats probably the best bet. I have an old Actron that I will plug in and see what I get too. Is sending out the ECU as simple as it sounds ? Does anything get screwed up when you re-install ? Keys, fobs etc ? Thanks all.
@belair62 When I had to remove my Range AFM disabler to pass smog the motor developed some really strange lifter tapping that would come and go. After that I tuned AFM out for good and sold the Range AFM device.Dustin what issues did you see re-activating AFM ? I feel like i'm walking on eggshells with this AFM stuff
Why don't you attribute it to the fact that the V4 mode lifters (their hardware, as designed) are a liability that GM passed on to us?About a month after the lifter noise started i had a lifter failure, and I attribute it to have AFM disabled for so long and then re-enabling it for smog.
Went with a full AFM delete after that.
Probably STILL a good idea to delete / replace the V4 mode hardware with V8 mode stuff.Was always worried something like that could happen! In my case I disabled it (programmed) before scheduled oil change.. so I got dirty oil in my VLOM!
Hopefully that won't cause issues being disabled. Afraid they want to look for checksums ... no way I'm ever enabling AFM.
Definitely planning to delete it.. but probably not for a year or so..Probably STILL a good idea to delete / replace the V4 mode hardware with V8 mode stuff.
A proper tune corrects the checksums.
You're splitting hairs, nobody would disagree with your statement. My statement simply outlines conditions that I believe to put further strain on an already fragile system (AFM).Why don't you attribute it to the fact that the V4 mode lifters (their hardware, as designed) are a liability that GM passed on to us?
That said, you deleted the V4 mode stuff. Congrats.
@MikesZ71 Personally I would run it as long as you are having no problems, unless your goal is to delete it before you have a lifter failure. Otherwise just educate yourself and prepare for the day that id does happen. When I had a lifter failure I scrambled a bit because I wasn't certain how to go about getting my Tahoe back on the road. I ended up doing the AFM delete ($1400ish with tools) myself in my driveway in the middle of July, that was last year and it still runs perfect.Was always worried something like that could happen! In my case I disabled it (programmed) before scheduled oil change.. so I got dirty oil in my VLOM! Hopefully that won't cause issues being disabled.. Afraid they want to look for checksums.. no way I'm ever enabling AFM.
@mikez71 Once you have AFM tuned out you are already set to do the mechanical AFM delete, the VLOM plug just hangs there after you rebuild the motor with non AFM parts. @BlackBearPerf is a good tuning service if you don't want to DIY a tune.Definitely planning to delete it.. but probably not for a year or so..
Who can do proper tunes?
Seem to read about people reverting to stock tunes, can it pass with VLOM disconnected running stock tune?
