Check those hub bolts, folks!
CrashTestDummy
Pearland, Texas
We heard a grinding noise in the front of my bride's Tahoe. The noise only occurred when backing somewhere. It has 110+K miles on it, and I don't know the history of it, so started thinking hubs or brake pads. When I had the front wheels off the ground testing for hubs, I noticed that the outer edges of the left rotor were ground, like rotor to backing plate, so ordered $300+ in pads and rotors. It's a PPV, so brakes are big, and $$$$.
Today was the day. She wasn't on call, and the weather wasn't too bad. Got the front left wheel off and had a closer inspection of the brakes. There's plenty of material on the pads, and other than the ground bit on the one rotor, the rotors looked good. Started looking around some more and it looked like the caliper wasn't square to the caliper adapter bracket. On a deeper-dive, I discovered that the bottom hub bolt was almost gone. It was proud of the spindle by almost 1/2". I checked the other hub bolts and they were all hand tight, or, hand loose, as the case may be. Got those re-torqued (132 lb-ft, BTW) and checked the other side to discover a similar situation.
Guessing the PO Sheriff's department had hubs, and possibly pads replaced before retiring the truck, and the tech decided his 3/8" ratchet got the hub bolts 'good enough'. So, yikes that a wheel(s) almost came off, and yaay, we have rotors and pads in the spares pile for this thing.
Charli1964
