Cheap GMG motor mounts @ amazon
OBSandaNNBS
Known Thread-jacker
NNBS motor mounts are $87 on Amazon right now.
I bought them in the spring but didn't get to it and returned them. $124 each.
Yes it's GM genuine. Exact same listing I bought before.
Black Friday starts tomorrow (? Whatever...) so maybe they will drop but I'm happy with $80 savings.
I didn't check the hummer mount.
A great deal, if they turn out to be genuine GM parts. It is easy to state that in an advertising headline, but the physical inspection will confirm.
Charlie207
LFOD, New Hampshire
Is this the solid rubber mount, or the fluid-filled/hydraulic mount?
NM, hydraulic: https://www.rockauto.com/en/moreinfo.php?pk=6437442&cc=3305736&pt=5552&jsn=583
There's the solid mount on Amazon: https://www.amazon.com/ACDelco-25847739-Original-Equipment-Motor/dp/B010GPIUBO?ufe=app_do:amzn1.fos.5998aa40-ec6f-4947-a68f-cd087fee0848
edit #2: These are back in stock, and you get two solid mounts for the price listed ($175): https://metaltek-manufacturing.myshopify.com/products/gmt900-lt-swap-mounts-2007-2013
Edit 3: Also saw these... interesting design: https://risingtuning.com/technical-tuning/product-4758
OBSandaNNBS
OBSandaNNBS
Known Thread-jacker
Should be OEM fluid filled based on part number.
mikez71
My buddies small newer bmw wagon needs a new motor mount too. Guess all balloons pop...
Maybe hydro mounts need a bumpstop/torque strap..
Let the balloon soak up idle vibrations, but once you're moderate on the gas, you'd be up against the stops..
Of course companies would not spend money to lose profit. I'm just being ridiculous.
j91z28d1
the oem mounts actually do have a mechanical interlock to them. that's what you see it hitting metal to metal in the tests of holding the brake and hitting the gas. maybe it's just allows to much? either way I like the hydraulic mounts, they just needed to make time stronger.
RobK
