My front right side uppe ball joint needs replacement.
I drive this old 2001 Tahoe about 3000 miles per year. It has 250000 miles on the gauge.
Questions:
This is an old worn rusty car that is only used for short trips to the scrap yard, to buy building material etc., so I don't like to spend any more money than absolutely necessary on it.
The car:
CHEVROLET TAHOE 2001 (B2W) 5.3 V8 AWD, 273 hp
Questions:
- Do I need a wheel alignment after changing a ball joint?
- Should I change left side upper at the same time as the right side? (Do both sides wear similarily?)
- Should I change the lower ball joint(s) at the same time? Do the lower ball joints wear similarily as the upper?
The car:
