and can parking brake pedal assemblies really wear out?
2001 Tahoe LS with 207K miles.
I've replaced parking brake shoes, the hardware that comes in the parking brake hardware kit, paid real close attention to getting the small cylindrical tappet seated against the actuating lever, I've ajusted the parking brake shoes so they just start to scratch the hub when rotating, and I've adjusted the nut between the intermediate and rear cables as tight as it can go. But the parking brake still doesn't hold.
Could stretched parking brake cables be the problem like internet searches say? Seems to me a steel cable won't stretch an appreciable amount.
Could it be the parking brake pedal assembly? Full pedal travel gives me just under two inches of cable travel within the cable sheathing. In the picture from behind the pedal assembly, everything within the two outer plates moves together with pedal travel. The brass-colored wheel doesn't turn independently, the spring wrapped around it doesn't move. In the picture from the front of the assembly, the brass-colored wheel rotates with pedal travel but the spring coiled around it doesn't move. Seems like something more should be going on in here with all the pieces!
I probably should go back and recheck the brake internals, too, but I'd like some advice before replacing everything else first. Any recommendations?
Thanks,
Jim in Virginia
Thanks,
Jim in Virginia
