My upper oil cooler hose burst on the highway. I noticed the oil gauge dropping to zero and pulled over right away and the motor stalled. The temp never went above 100 degrees. I changed out the hose and filled it up and it fired right up. However there is now a light knock in the bottom end some where and the oil pressure gauge shows really high pressure. Can anyone point me in a possible direction? This motor was fully rebuilt with a high flow oil pump and new crank two years ago. I would hate to have to rebuild it again!!
I took another look and the oil pressure gauge drops to zero when it's not running and goes up to 375 when it's running so it seems the oil pressure sending unit is working. Prior to this it would max out around 290 and go up and down with the motor revs.
I checked for codes and there aren't any.
Would a plugged radiator oil cooler cause the oil pressure to spike like that and burst the hose? I will disconnect both oil cooler lines tomorrow and put them together with a hose and clamps to cut out the oil cooler and see if the pressure drops. Any other ideas would be appreciated.
