Yikes! I'd be ready to melt that thing outta there!
Then again, I've had a few whisky bottles look like that when the cork splits in half while I'm trying to sneak a belt...
I totally agree with you. And believe me, I was ready to set the engine on fire after the amount of sweat I lost working on this damn thing.
Are you able to stick your finger in there and press on the end of the sensor? If yes, I'd refrain from trying to drill all the way through the sensor (to prevent crud from falling into the oil pan), and slowly work up in drill bit size, so that you remove material as close the aluminum surrounding the sensor, until you can press it out the front.
If you haven't been able to pull the entire piece out, you 100% can't. It's swollen, and wedged in there.
I was only able to get it out so far. I tried every damn extractor I owned. I tried pushing from the back side, drilled and JB welded a lag bolt inside, heated, iced it, nodda! It came out to where the sensor was flush with the inner lip of the timing cover.
Even after taking the cover off, I still had to heat it up, drilled through it completely in the center and once near the outside edge to weaken it a little bit. Then took a brass punch close to the size of the sensor and knock it from the back side. I was tired of messing with it by then and ordered a new cover.
Hopefully I can get it centered on there enough with the balancer without having to order a tool that I will only use once. I’m not sure if the auto parts store would have a loaner tool specific to the Gen IV.
When the time comes for a mechanical AFM/DoD delete, I will probably go ahead with a new timing chain/pump kit as well, so I guess the question is, should I replace the VVT solenoid/actuator bolt while I have the cover removed, or wait until I need to do the timing chain?
Anyone have any thoughts on this topic?
