Brake Pedal Squeak - Power Brake Booster Replacement 2018
jgold47
I had been dealing with a brake pedal squeak (2018 Escalade, 100K miles)- coming from the pedal itself, not the actual brakes. It would only show up if I pressed the pedal repeatedly (think backing out of a spot), and sounded like a dog's squeaky toy. I wound up replacing the brake booster and not only solved the problem, but I think my brakes feel much smoother as well. The install was fairly easy, its a lot of contorting to get the 4 bolts off from inside the car. I used a series of extensions and wobble/angles to get it out from under the dash, but wasnt complicated. outside the car, there's definitely some manouvering needed, but can be done with one person, although a partner helps. 2 bits of additional advice - getting the vaccum sensor in and out was the more frustrating part, but solvable. Also, the master cylendar gets moved out of the way, you have more room to move it than you think. All in all it took me about 30 minutes.
sailflow
