BRAAP
- Joined
- May 14, 2019
- Posts
- 14
- Reaction score
- 10
Is there enough body/chassis flex to tear apart our radiators?
01 Burb 1500 4wd, 3” level/lift, 250,000 mi, sees mild off-road, couple times experienced enough off-camber articulation to lift a tire.
Original radiator has been leaking for a little while finally diagnosed it, cracked tank driver side, crack started approx 2” below the rad inlet neck and ran 4”+ down. Installed brand new radiator last week, it’s leaking from at least one core tube where it enters the cast part that the tank clamps on to.
I’m hoping my original rad was just brittle from age and let go on its own, and the new rad is just poor quality control from manufacturer, or is chassis flex great enough that I’m tearing radiators apart?
I would expect due to the radiators mounting system it compensates for chassis body flex about the core support and shouldn’t affect the radiator. Bottom sits loosely in 2 rubber nipples, upper mount the rad is slotted and held somewhat loosely in a rubber grommet that lightly squeezes the mount yet should allow some movement in the event the body/chassis flexes?
Input and experience from others that wheel their half ton Burb/Hoe?
