Hi all, I just picked up 2 Tahoes, an 02' and an 04' on the cheap. They are both clean titles and both are complete and road worthy but neither one of them are running properly at the moment. They have both been heavily modified and the guy knew what he was doing for the most part but he got in over his head and was having other people work on them so there are some issues. I've decided to pick the 04 for the first one because it's newer, has less miles on it, and has the least amount of issues.
So the first and foremost problem is the charging system. The truck will start and run but it has 2 batteries, a high output alternator, high powered stereo system (non stock), winch, air suspension (not stock), and a bunch of off road lights (under, on the hood/cowl, roof rack (all 4 sides), and wiring for heavy duty trailer). The batteries won't stay charged, it needs to be jump started every morning. It will start on it's own after a short off period but no more than a couple of hours.
Needless to say that's a lot of circuitry to test to find the drain. I do realize that it needs new batteries but before I go dropping a few hundred on some good ones I have decided that I want to bring it back to a stock base line and work out from there, one component at a time. I have purchased an inexpensive battery from the store I work at and have disconnected the second battery and all the components. I left all the wiring intact and capped off all exposed connectors and coiled all the leads up out of the way of any possibility of metal contact with the vehicle and any moving parts.
Now I am at the point of establishing the basic battery, alternator, starter connections just to get it to run and charge normally. The issue I'm facing is that I'm working with the cables that are existing because they are all in good shape and high quality but the system has been modified and I have to figure out which cables to keep in place and which ones are not necessary. The way it's wired is; a large (2 gauge) cable from the alternator + post to the positive battery cable, another (4gauge) going from the alternator + post to a red box labeled "battery + bolted to the alternator bracket grounding plate.The red box appears to be isolated from the mount therefore eliminating a short there but I'm not certain of that yet. From that red box there are 2 other 4 gauge wires, one comes back out the top next to where the alternator wire goes in and the other exits the bottom and runs along the front and side of the oil pan to the starter. The one that comes out the top I thought went to the positive block next to the battery that connects to the second battery but I somehow missed it when I was labelling them when I disconnected everything. It fell down under the others and I didn't notice it until I was preparing to reconnect the ones I need. Anyway There's a 4 gauge wire from the positive battery to the block that ran positives to the second battery. From that block there's a cable that ran to the second battery that I have disconnected, isolated, and put out of the way and another wire that goes down and runs the path with the one that goes to the starter but I haven't traced that one yet. I'm getting ready to do that now but I've come to the conclusion that I'm going to need help with this so I've decided to throw this out there so that some of you will have a chance to see it and hopefully offer some advise which I can read after I chase these last couple of cables. The only other one up top that's questionable is one that exits the bottom of the fuse block at the inner fender. I have it labelled as negative but I actually don't even recall disconnecting it and I don't think there were any other cables connected to the negative than the one that ran to the second battery. I've been picking at this evenings after work so these little things are catching up to me and I want to get this base line right before I try to connect the new battery.
Sorry for the lengthy post but there's a lot going on under this hood and I figure the more I can include about the issue, the better the chance of getting some helpful info. So to recap, I'm just trying to get this thing to run and charge a single battery with no optional accessories for the time being. Thanks in advance for any helpful info.
