Big 3 and Amp wire upgrade
fyremanpat
Fyremanpat
So I had enough of literally melting fuses in my amp power wire, I ordered 30 ft of 0 gauge wire to re-wire it and do a big 3 upgrade...trouble is NO one carries 0 gauge ring terminals around here, and if they do they $15 for two. Looks like Im gonna be making my terminals. I will post some pics!
fyremanpat
fyremanpat
Fyremanpat
Yep! Exactly what I was thinking...Probably gonna have to order new battery terminals though
clean454
auto part stores should have them thats where i got mine
well some
the rest i found in blizzards garage
BigDaddy13440
Rome, NY
Go to a welding equipment store, I'm sure they have them for 0 gauge. Quite possibly, they might even have them for 4/0!
fyremanpat
fyremanpat
Fyremanpat
Couldnt find terminals so I made them. 1/2 inch copper pipe seemed to do the trick
$1.75 a foot through ebay
Tried to keep it looking as stock as possible. Big 3 DONE..just gotta run the amp power tomorrow.
boble94
GM All The Way!
Lincoln, NE
your filter looks dirty.
lol.
other than that, it looks great man. like stock.
fyremanpat
fyremanpat
Fyremanpat
OK OK I cleaned my filter today too and finished the amp install..will have pics up later
fyremanpat
fyremanpat
Fyremanpat
and now finally finished and air filter all cleaned up just for boble94. haha
and after doing all this I would tell everyone who plans on doing this to go with 4 gauge..0 gauge is just wayyyy to hard to work with, especially when its cold out. Hope this helps.
The alternator is new but its suppose to be oe from advanced autoparts..its a 120 amp (I think)
newmarketeod
This may be stupid, but I am looking to do this but am not exactly sure wich wires I am upgrading. Could someone fill me in?
fyremanpat
fyremanpat
Fyremanpat
the k&n cleaner and oil
The big 3 is alt. to batt., the batt ground, engine to ground
fyremanpat
fyremanpat
Fyremanpat
The battery ground on the engine is on the passenger side behind the harmonic balancer, next to the crank position sensor. You can see it and access it from below or above. It has a few other wires grounded on it as well.
riviera rider
nice im running all my 1/0 guage this weekend and doing my big 3 upgrade as well as installing my 190a alt from dc power :)
fyremanpat
fyremanpat
Fyremanpat
I learned that if its cold outside the wire is a real bear to work with, I also learned that if you heat it up ( ceramic heater) its 10x easier..Good luck and post pics when your done!
Woned2004
