Backup camera
Ken Redfearn
I have the GM Lock pick Pro installed with a backup camera up front. Works fine except the image is reversed. I read somewhere that there is a green wire inside the camera cable that gets cut to correct the image. So i spliced mine open and there is no green wire just red, black and yellow. Question is did I splice in the wrong spot and miss where the wire may be or do I need to get a different camera. Can someone help me out???
EMizzle
Chicago
Sounds like you need a different camera. I got a Lockpick GMX AIR with 5 total cameras, including the backup camera. My rear camera is aftermarket and similar to the stock camera. My front, sides and 2nd read camera are flush mount, those had green and white wires that I could cut to either reverse the image or show guidelines.
