RI95Tahoe
1995 Suburban 5.7L Automatic 4WD.
Truck was running rich (could smell fuel in the exhaust), had to feather it to get it to drive (anything over 1/4 throttle would cause it to sputter and backfire both exhaust and intake).
Done so far:
Replaced fuel regulator (old one had a small tear in it)
Replaced TPS (tested and it was bad)
Full tune-up (plugs, cap, rotor, wires)
Note: Old plugs were burned one one side of electrode but clean on other side
Test coolant temp sensor and tested within Ohm limits
Checked spray pattern with stobe light -- good spray
Timing is at 0 deg with computer disconnected
Disconnected EGR valve and plugged line (no changes)
I do have a code for the IAC, which truck does idle high when you cold start it and returns to normal once warmed up
So....I'm at a point where the truck idles great, no issues when I rev it up in park (revs smoothly up and down), but as soon as I attempt to drive it it cuts out then backfires through intake. Will idle in gear without an issue.
Any insight would be appreciated. Really can't afford to keep throwing parts into it.
Done so far:
