Are the heater hose quick connects really needed?
Meathead16
I did a search but mostly found threads about the heater hose T's and systems that had rear heat. I can see why the quick connects would be needed in those applications.
My quick connects are starting to leak, and at 250k on the originals, I'm lucky they haven't blown out. I bought a replacement hose that connects the heater core, overfill tank and water pump, but accidentally ordered one for vehicles with the rear aux system, which my truck does not have, so the quick connects didn't fit. I was looking at the metal quick connects from dorman but was also thinking.. since I don't have the rear system to worry about, can I just forgo the quick connects and slide the hose right onto the heater core fittings and secure them with some clamps?
I figure GM started using quick connects as an assembly line efficiency measure, but beyond that is there anything about the design that would require the quick connects to be used? I'm doing a parts order right now and am not near the truck or I would try and push them on myself to see how they fit, and the order needs to be in before I'll have a chance to do so. Has anyone else tried this?
mikez71
One possible issue is the heater hose getting stuck on the heater tubing (well it happened in an old turbo vehicle of mine). It made removing the hose difficult, and you can deform the heater connections prying the stuck hose off.
Doubt that would happen on a NA motor though..
nonickatall
Germany
I would choose the quick connect system because it's simply a reliable fastening method; that's why manufacturers use it – it's quick and secure to assemble during production and it holds. It's understandable that the plastic parts might harden after 20 years due to the engine heat and then crack, but if you use new parts, you'll have peace of mind for 20 years.
Of course, you can also do it with a pipe and hose clamps, but that's usually fiddly and not necessarily more stable.
So from my view, just get the original part, install it, and be save the next century...
Folks have done it both ways successfully, so the choice is yours. You've been given a good set of pros and cons on this topic.
Let us know what you eventually decide to do.
alexblagoev
