Are My Pitman or Idler Arms Bad?
ssalvat
I'm trying to track down the cause of loose steering in a 2006 GMC Yukon XL 1500 with the 5.3L Z Flex engine. I went to get it aligned a little while ago and was told the shop couldn't get it set properly because of the pitman/idler arm, so I was planning to replace them. I had the front end up in the air getting ready to work on a lower ball joint (side note, if you're considering this you might think about replacing the entire LCA, that ball joint is really in there) so I thought I'd give the wheels a shake and see if there was obvious play in the arms.
Unfortunately I didn't have a helper so I had to take the video myself, lighting and angle aren't great, but based on this does anything jump out as bad?
If it helps it feels like there's way more play in the steering when the wheels are on the ground than when they're in the air. I'm almost certain one of the inner tie rods is bad, I could feel it move and hear it, but I can't imagine that would explain how much play is in the steering when the wheels are on the ground. Do I just need to retest on the ground with a helper?
Any advice here would be very much appreciated.
Here's a link to the video: https://streamable.com/7qg7xj
mikez71
I would retest on ground.
(Since there isn't much resistance with wheels up and steering column spinning..)
Position camera, then crank on steering wheel.
Sik Rik
